Go to Post If 100 people from ChiefDelphi all wrote one full article on something that they are an 'expert' in, FIRSTwiki would be even better. - artdutra04 [more]
Unread 30-01-2010, 10:05
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: Data File Writing ... cRIO vs. Driver Station
Good advice. Saturday is an all day session w/ the team and we'll look at the examples ...
... but looking at the bigger picture ... what are the pros & cons of writing the file onto the cRIO vs. writing it onto the driver station? I've got a few ideas, but still appreciate advice from the folks that have already done this a lot.
Keep in mind that my data is simple columns of speeds, encoder values, accel values, etc. Some of my assumptions may be bogus if dealing with images or other sorts of data.
If the data is already available at both locations, then it'd probably be more "convenient" to be able to get the file copied off of the DS vs the extra file transfer from the cRIO.
I don't think resolution is a factor. Right? Putting the file-write into the teleop.vi, getting called at 50 Hz would result in the same rate as a driver station write ... giving me equal results.
The "saveImageFile.vi" example uses a target path of "c:\images" ... does the cRIO filesystem emulate a DOS-like filespace? How much filespace is there available on the cRIO to write to anyway?
I'm off to the team meeting ... looking forward to our results, and then coming back here to discuss.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Logging console data to text file on crio Kingofl337 Programming 3 09-04-2009 18:57
cRIO "Magic" Values: Unresponsive Driver Station KRV NI LabVIEW 0 13-02-2009 17:33
driver station and cRIO firmware update help asianfez123 FRC Control System 1 16-01-2009 02:34
cRIO/Driver Station output to laptop smcmahon FRC Control System 3 14-12-2008 13:51
Reading binary data from a file and writing it in VB complete Programming 1 02-01-2006 21:21
