Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 30-01-2010, 10:59
SAFETY WARNING: <R77> 125 psi Pressure Relief Valve
Our team has just discovered this morning that the Norgren "125" psi relief valve as supplied in the KoP was NOT calibrated to 125 psi.
We took it up to 160psi and it did not release.
Rule <R77> states in bold letters that Teams are not allowed to adjust the 125-psi relief valve.
The "Pneumatics Manual" at the USFIRST website says nothing about adjusting this valve.
Are other teams aware of this potential safety issue?
Unread 30-01-2010, 12:58
GaryVoshol's Avatar
Cogito ergo arbitro
Re: SAFETY WARNING: <R77> 125 psi Pressure Relief Valve
Please continue this discussion on the thread in pneumatics: http://www.chiefdelphi.com/forums/sh...ad.php?t=81485
(Because it's a potential hazard, I elected not to delete the duplicate post)
(since 2004)
120 psi pressure reliefg valve falconmaster General Forum 5 31-01-2010 01:06
Adjustable pressure relief valve? ayeckley Pneumatics 18 29-01-2010 14:46
120 psi Main Relief Valve not functioning Clifford Pneumatics 10 11-02-2008 22:29
Calibration of pressure relief valve d235j Pneumatics 3 16-01-2008 14:12
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
