Go to Post And you wonder why these guys are figuring out where to hang another Chairman's banner. :) - Billfred [more]
Unread 28-01-2010, 10:16
Rikard023's Avatar
Rikard023 Rikard023 is offline
Programmer/Animator/Captain/Ninja
AKA: Rikard
FRC #0522 (The Robowizards)
Rikard023 is an unknown quantity at this point
Send a message via AIM to Rikard023
windriver help
sorry bout the post below accidentally deleted it
Ok..now I load the program to my kit bot and the autonomous works get but the teleop wont run at all
In the diagnostics section on the driver station i get an error
Fatal error "Attempting to rescue an allocated resource" in Allocate() in C:/Windriver/workspace/WPIlib/Resource.cpp at line 79
if i go to line 79 it says
77-if (m_isAllocated[index] )
78-{
79-wpi_fatal(ResourceAlreadyAllocated);
80-return 0;
and i dont know what this means
could this be why it is not working and if so can anyone help
"Sharp edges are prone to cause bleeding trust me i know" T.T
http://www.robowizards.com
Unread 30-01-2010, 12:37
Rikard023's Avatar
AKA: Rikard
Re: windriver help
PLease help im getting desperate
Unread 30-01-2010, 12:44
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
Re: windriver help
We had this problem too. Make sure you updates are all applied.
Did you have aprevious version of Windriver loaded on your computer?
What platform is running Windriver.
Unread 01-02-2010, 07:05
Rikard023's Avatar
AKA: Rikard
Re: windriver help
I didn't have a pervious version running i put windriver on the netbook FIRST gave then teams. I fixed my problem now though, I just re-wrote my program over one of the example programs FIRST gave us
Unread 04-02-2010, 18:34
Hal'sWorld's Avatar
Hal'sWorld Hal'sWorld is offline
AKA: Halley
FRC #0547 (F.E.A.R.)
Hal'sWorld is an unknown quantity at this point
Re: windriver help
We're having the same problem, but we have updated. Could you please explain how you fixed the error?
Unread 05-02-2010, 09:44
Rikard023's Avatar
AKA: Rikard
Re: windriver help
To explain exactly what i did i took my program i was already writing and just copied it to a different example template and it worked that and We wired the robot right this time post some of your code i could help
Unread 05-02-2010, 11:22
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: windriver help
We got this error when the code was looking for a sensor in the wrong (slot, port) combinations(s). Make sure that you're initializing your sensor objects to the correct slot and port(s), reboot the robot, and the problem should disappear.
Dashboard Help C++ Windriver ranc Programming 0 15-01-2010 15:26
Please help Program Relays in WindRiver.... programmr Programming 6 28-01-2009 11:42
Need help in c++ and windriver jkjohnson C/C++ 3 13-01-2009 18:50
help:Downloading the project in windriver mahmosh C/C++ 5 10-01-2009 10:08
