Go to Post In order to change the world and make it a better place we must start with ourselves. - wendymom [more]
Unread 30-01-2010, 13:10
iTHOS=awesome iTHOS=awesome is offline
FRC #1258
iTHOS=awesome is an unknown quantity at this point
Send a message via MSN to iTHOS=awesome
Solenoid Breakouts?
Our electronics team has decided to use the solenoid (sp?) breakout on the cRio this year. My question is ... how do you define a solenoid (sp?) and control it in C++?
Unread 31-01-2010, 01:03
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Solenoid Breakouts?
You use the (big surprise... spoiler alert...) Solenoid class. Pass the channel (and optionally the module slot) to the constructor. Then call Set to set the value. Probably the simplest class in the library.
I'm guessing you posted this before looking at the library. Or did you have a specific question that you forgot to include?
Unread 03-02-2010, 21:29
KRibordy KRibordy is offline
FRC #1000 (Cybearcats)
KRibordy is an unknown quantity at this point
I tried getting this to work today; I managed to get a green light on the solenoid breakout, but after defining the solenoid objects, using the Set() function did nothing.
Our code looks something like this.
Solenoid *solenoidOne;
Solenoid *solenoidTwo;
solenoidOne = new Solenoid(1);
solenoidTwo = new Solenoid(2);
Into operator code...
if(joystick->GetTrigger()) {
solenoidOne->Set(true);
solenoidTwo->Set(false);
else {
solenoidOne->Set(false);
solenoidTwo->Set(true);
I might be doing something completely wrong here. This our first year using pneumatics with the new control system, so I'm a bit confused. The code manages to get into the if statement, but the solenoid commands do nothing. Is there anything glaringly wrong that you can see?
Unread 03-02-2010, 22:04
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
We were having the same problem today on our robot, does your solenoid have little buttons you can press to release pressure also? If so try pressing them and if it works it means you have your solenoid wired correctly.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 03-02-2010, 22:52
Originally Posted by KRibordy View Post
...the solenoid commands do nothing.
Before we do any detailed debugging, did you remember to Enable the robot?
Unread 04-02-2010, 19:49
Yes. Everything else ran fine, (except for the stuttering caused by the watchdog glitch) including the jaguars and camera feed. We just plugged the solenoid breakout into the cRIO and then ran two wires from the solenoid breakout, one to each end of the solenoid assembly. Again, we haven't used the new system to control pneumatics, so I may be missing a critical step here.
Unread 04-02-2010, 22:55
Which slot did you plug the module into? The code expects it in slot 8 by default. Do you have the compressor working? Most solenoid valves won't do anything without air pressure. Have you observed whether or not the green lights on the cRIO digital output module are changing when you press the trigger?
Unread 05-02-2010, 16:47
I'm pretty sure we didn't have it in slot eight; we were running the compressor off an external battery, so that code wouldn't be the problem. Why would the cRIO digital output be affected? We're running the solenoids from the solenoid breakout, right?
EDIT: We hooked the solenoid breakout to the 9472 module in slot eight. We connected the two cables to either side of the solenoid and used the code above...but nothing worked.
The buttons on the solenoid do work for switching, but the trigger does not.
Unread 05-02-2010, 22:32
The solenoid breakout had better be on the digital output module, or it won't do anything.
You're providing power to the solenoid breakout, right? The voltage needs to match what the solenoid expects, either 12 or 24 volts, following the power diagram on the FIRST web site.
When you say "nothing worked", does that include no green lights on the output module?
Unread 09-02-2010, 20:37
We solved our problem; it turned out to be a multitude of different problems with our code. I changed the code from using "true" and "false" to using "0" and "1" and also moved the module to slot eight. By removing all of our code except the solenoid commands, we were able to get the solenoid to switch back and forth between the two outputs every few seconds. Thanks!
Unread 20-02-2010, 21:14
superstretch superstretch is offline
FRC #0417
superstretch is an unknown quantity at this point
shouldn't using true/false or 1/0 not make a difference?
Unread 21-02-2010, 13:09
That probably didn't; we changed a few things to make it work. But it works now, so I'm not worried.
multiple solenoid breakouts Wendy Holladay Electrical 2 26-01-2010 09:10
2 SOLENOID BREAKOUTS? Legal? BaByGrL Pneumatics 1 19-01-2010 14:04
Solenoid Question RookieWookiez Pneumatics 2 18-01-2010 18:35
how many analog breakouts do we actually need? team2192 Electrical 6 16-01-2010 11:25
Programming a Solenoid Brigander Pneumatics 4 17-02-2007 14:06
