Go to Post Consider that the 12V from your robot isn't any different from the 12V from your car's cigarette lighter. (Err... sorry... that's "power port" these days, thank goodness.) - dtengineering [more]
Unread 30-01-2010, 14:43
caincteam2777 caincteam2777 is offline
FRC #2777
caincteam2777 has a spectacular aura aboutcaincteam2777 has a spectacular aura about
Question Bumper Question
So for this year's competetion we have to be able to switch our robot's bumper color, is each team required to create a skin to use to switch the color, or will we be provided with one when we reach competetion?
Thanks,
Unread 30-01-2010, 14:50
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Re: Bumper Question
Thanks,
You get the pleasure of building your own! They do not provide them for you. See <R07 E & F> and <R12> for details.
<R07>
E. The BUMPERS must be covered with a rugged, smooth cloth (1000 dernier Cordura PlusŪ strongly recommended). The cloth must completely enclose all exposed surfaces of the BUMPER backing (plywood) and cushion (pool noodle) material. It is recommended that lengths of aluminum angle be used to clamp the fabric in place.
F. The fabric covering the BUMPERS must be solid red or solid blue in color. Visually, the red or blue must be as close to the corresponding color in the FIRST logo as reasonable (i.e. to a reasonably astute observer, they appear similar). The only markings permitted on the BUMPER fabric cover are the team number (see Rule <R15>).
<R12>
The color of the BUMPERS will be used to identify the ALLIANCE to which the ROBOT has been assigned, red or blue. Therefore, each ROBOT must be able to display red BUMPERS and blue BUMPERS This may be done via either of two acceptable methods:
B.
Each ROBOT may be built with two complete sets of interchangeable BUMPERS, one red and one blue. If this method is chosen, the BUMPERS must be identical except for the color of the covering fabric (see Rule <R07-F>).
The BUMPERS may be constructed with a fabric covering of one color (see Rule <R07-F>), and then covered with a removable fabric shroud of the opposite color when appropriate. The removable cover must completely enclose the BUMPERS and conceal the contrasting fabric. The cover must be constructed solely of fabric and a fastening/restraining system to hold the cover in place. The fastening/restraining system must extend no further than one inch beyond the FRAME PERIMETER (i.e. no further than any other hard parts of the BUMPER - see Rule <R07-N>). Please note that the fastening/restraining system MUST be designed with robust performance in mind. The restraints must hold the removable cover in place during vigorous interactions with other ROBOTS and FIELD elements during the MATCH without allowing the cover to come off.
Best regards,
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 30-01-2010, 15:02
gilkeedman gilkeedman is offline
Team captain/Pneumatics/Mechanics
AKA: Gil 'Dil Tedem' Kedem
FRC #2630 (Thunderbolts)
gilkeedman is an unknown quantity at this point
Re: Bumper Question
In our regional kickoff they told us that you need to build your own but when they check your bumper whight they will check evrything thats connected to the bumpers
in other words dont do another set of bumper just make a set with one color and a cover with other color
2007 - Israeli regional FLL team member, 2008 - Fomula Green-8075 FLL team member, Israel's champions
2009 - Israel FLL referee and Thunderbolts team member
2010 - Thunderbolts, Israeli regional champions, Curie semifinals
2011 - Thunderbolts captain
Thunderbolts 2630 website!!
Unread 30-01-2010, 15:25
FlyingHedgeHog's Avatar
FlyingHedgeHog FlyingHedgeHog is offline
AKA: Jonathan
FlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud of
Re: Bumper Question
You can build your own sets of bumpers, your own cover, or you can buy a bumper skirt from andymark. http://www.andymark.biz/am-0587.html
Unread 30-01-2010, 16:00
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Bumper Question
The rules specifically allow for two identical sets to be made. The combined weight is not measured, just the weight of each set.
Unread 30-01-2010, 17:39
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Re: Bumper Question
Thanks,
While some teams are opting to create a skin for easy removal, it is not required. Our team plans on creating two separate sets of bumpers, one of each color, but that is just how we are doing it...
Bumper Question minirose224 Kit & Additional Hardware 6 17-02-2008 00:13
Bumper Question UBY General Forum 5 13-02-2008 18:47
bumper question stiffler Technical Discussion 2 31-01-2008 19:14
bumper question batterybox General Forum 5 17-01-2008 15:50
bumper question math4origami Rules/Strategy 4 16-01-2007 14:47
