Go to Post I might be singing a different tune if I get a water jet for Christmas. :) - FrankJ [more]
Unread 30-01-2010, 16:20
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
Team 675 Kicker
Here is team 675's kicker as of yesterday night.
check it out
http://www.youtube.com/watch?v=UF1_6EqdhYU
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 30-01-2010, 16:25
RookieWookiez's Avatar
RookieWookiez RookieWookiez is offline
Scouting Student Leader
AKA: Dane Potter and Others
FRC #3138 (Innovators)
Team Role: Scout
RookieWookiez is an unknown quantity at this point
Re: Team 675 Kicker
It looks really cool, but is your team going to add something onto your robot that'll limit how far the ball will go in? Cause throughout the video I kept thinking that the ball would go into your robot a lot more than three inches.
Unread 30-01-2010, 16:32
"Wilfordito"
Re: Team 675 Kicker
Yeah that surgical tubing was only a temporary fix, we are currently machining the stop as we speak. As well as adding the motors and transmissions etc. lol
Unread 30-01-2010, 16:34
Team Role: Scout
Re: Team 675 Kicker
Lol alright, cool. I figured that's what your team was doing, but just wanted to make sure.
Unread 30-01-2010, 16:36
"Wilfordito"
Re: Team 675 Kicker
Nope, i agree I'd rather be safe than sorry.
Unread 30-01-2010, 17:35
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
Re: Team 675 Kicker
Are those mechanum wheels on your proto?
Unread 30-01-2010, 17:51
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
Re: Team 675 Kicker
What kind of cylinders are you using? It did not look like the bimba cylinders and also how do you have the air line plumbed, Ionly see one line going to each cylinder. Very nice job.
Unread 30-01-2010, 18:14
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Team 675 Kicker
Spring return cylinders I would imagine? Looks good! Very similar to our kicker design, it makes me confident to see it work so well!
Unread 30-01-2010, 22:33
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
Re: Team 675 Kicker
The kicker looks really nice. Are you planning on using a roller? Also are you going to have variable firing distance with the kicker?
Unread 30-01-2010, 23:05
"Wilfordito"
Re: Team 675 Kicker
Te respond to all of you.
They are Bimbas last time i checked, we ordered these this season I believe.
For the purposes of testing it was just our shops air flow which is maxed out at about 120 psi, but we took it down to 60. We will have a compressor and 2 solenoids for the cylinders to make sure that it continues to work as shown.
Last but not least those are mecanum wheels. and its not our prototype, that is actually our final chassis minus a few key components, transmissions, endgame piece, etc.
Unread 30-01-2010, 23:08
"Wilfordito"
Re: Team 675 Kicker
THe variable distance is based off of at the moment, top spin and back spin.
Top provides the aired shots, and back allows the ground shots. both shot about 16-22 or so. But to answer variance it could be as easy just adjusting the amount of pressure we take from our compressor. I'll get back to you when i know more details
Unread 31-01-2010, 15:27
infinitydex's Avatar
infinitydex infinitydex is offline
mr robotics man
AKA: Mr. I DESTROYED U
FRC #2932 (mid pac terminators)
Team Role: Operator
infinitydex will become famous soon enough
Cool Re: Team 675 Kicker
check it out
the only prolem i see is that u only have a kicker. no ball controll, no motors, no movement, running out of time and thats all u have done. you should try rethink the whole idea of spending 3 weeks on a kicker and 3 weeks of strees to finnish the frame, motors, mounting all of ur equipment. you have alot t do.
were done with our robot but we like ur kicker so thanks for the design
_______________
NO I WILL NOT FIX UR PC
the robotics team from my school is better then the robotics team at ur school
Unread 31-01-2010, 17:33
"Wilfordito"
Re: Team 675 Kicker
I appreciate and understand what you are saying, but this is not our first rodeo. I don't know how your intending to come off as, but That wasn't exactly the best display of gracious professionalism. To clarify, most of the robot just wasn't on the chassis. Electronics, the motors and transmissions, The ball controller, are all off of the robot during this test. We have been able to successfully do things during build season the past 10 years. I appreciate your concern but we are going to be just fine. I hope that you do well during this season. Out of curiosity I would very much like to see your robot. you are welcome for design as well.
Unread 31-01-2010, 17:37
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: Team 675 Kicker
What are the specs on the actuators?
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 31-01-2010, 17:39
"Wilfordito"
Re: Team 675 Kicker
Those are bimba cylinders with 5 inch stroke. and 1 and 1/16 inch bore.
Team 383 kicker prototype Manoel Robot Showcase 12 16-02-2010 15:54
Team 123 Kicker J. Stofflett Robot Showcase 9 31-01-2010 22:43
Team 675 Preview fieldd Robot Showcase 12 10-02-2009 12:54
Team 675 Pasta Feed fieldd Fundraising 0 02-05-2008 13:06
Team 675 'Delilah' MikeJ675 Robot Showcase 3 25-02-2005 14:10
