Go to Post If you speak three languages, you're trilingual. If you speak two languages, you're bilingual. And if you speak one language, you're American. - Hieb [more]
Unread 15-01-2010, 19:01
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Downloading code: Netbeans does not reset cRIO
When downloading code, Netbeans stops at "Setting up for RUN". When I reset the cRIO, the code then runs. In the past (before the official Java release, using Beta Java) Netbeans reset the cRIO for me. Additionally, I do not get a console to see the System.out.println's of my program, as I did in the past, when Netbeans reset the cRIO and stayed attached to the connection.
Both my computer and the cRIO have been updated (cRIO is at v19 and the computer has had the latest "Labview" update). Does anyone know how to fix this so that downloading and viewing println output work correctly?
Thanks.
Unread 16-01-2010, 16:06
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Downloading code: Netbeans does not reset cRIO
I've got the same problem on my personal laptop, although it works fine on the Classmate.
My laptop is running Ubuntu; I installed NetBeans and then used the plugin installer to get the FRC stuff. I also used the plugin installer to update NetBeans on the Classmate.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 16-01-2010, 22:23
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
I was having the same problem. What worked here was to go to Network Connections and use the default computer IP (10.6.10.6 in my case, 10.15.40.6 in yours) to connect. After that try running the program again.
Hope this helps!
Unread 18-01-2010, 22:37
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
Can you ping the cRIO?
The issue may be that the broadcast UDP packet info may not be making it to your machine. If your on Windows, then try running the NetConsole for LabView. If it does not work, then neither will ours.
Unread 19-01-2010, 11:37
cal3d cal3d is offline
FRC #0467 (Shrewsbury Colonials)
cal3d is an unknown quantity at this point
Make sure that your netmask is set correctly. We had this problem also, changing the netmask to the correct 255.0.0.0 fixed it.
Unread 20-01-2010, 17:13
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Hmm...that might explain it. My team has found that any computer with a static IP will download, while a computer using DHCP will not. This doesn't make sense, unless you consider that the router suggests a subnet mask of 255.255.255.0 rather than 255.0.0.0.
Go directly to queue. Do not pass pit.
Unread 30-01-2010, 15:29
greekgod8591 greekgod8591 is offline
FRC #2577
greekgod8591 is an unknown quantity at this point
I have the same issue. When I hit the build and run button my output line hangs on "set up for Run" It works when I reboot via the cRIO but I still want debug code. Any other ideas other than resetting the IP and checking the subnet mask?
Unread 30-01-2010, 16:57
FRC #2577
Okay, so after great searching of forums and googling, I have finally found one solution to the setting up for run issue. It turns out the windows firewall seems to have been blocking communication back from the cRIO resulting in the disruption. So, if you have this issue and setting a static IP didn't help, try turning off the windows firewall. It worked for us.
-2577
Unread 31-01-2010, 19:02
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
We are also seeing this issue, and we had to run a cable from the laptop to the router. I never had a issue before this build of squawk.
Code deploys but does not save to cRIO Bill Taylor NI LabVIEW 11 15-02-2012 20:30
Imaging Tool does not find cRIO aeasson FRC Control System 2 10-01-2010 20:39
0.00 Volts - Code Not Downloading - Randomly Works? R.C. Electrical 7 26-08-2009 13:52
downloading code to cRIO mint564 C/C++ 6 10-02-2009 19:30
Camera does not search in autonomous mode after reset Keith Watson Programming 17 07-03-2006 00:42
