Go to Post Recently my wife and I met some mentors from Michigan with their wives at Disney World. It seems that I'm not the only mentor who needs to bribe their wives with vacations before they sign up to mentor FRC for another year... - Mark Holschuh [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 30-01-2010, 11:05
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Slow update speed updating Jaguars
It's taking about 1/2hr to update a jaguar that seems off, any ideas?
Unread 30-01-2010, 17:18
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: Slow update speed updating Jaguars
What is your setup? For example, how are you Jaguars connected to the update computer, how are you powering them, etc?
Are you using bdc-comm in the command line or GUI?
List the steps you are taking.
-David
Unread 30-01-2010, 18:31
Kingofl337's Avatar
AKA: Adam
Figured it out, the RJ-12 was crimped upside down. The funny thing is while BDC-Comm was acting odd it looked like it was working. It wasn't until I re-crimped the connector I found out how it should work.
Now I just need to get more then one to work at a time. I've set the black jag to ID 5. Then plugged in a Grey Jag w/100ohm 1% terminator and the second Jag LED won't go solid, and BDC-Comm won't detect it.
The configuration is as shown in MDL-BDC24-GSG.pdf, Page 26, Figure 8-1
Unread 30-01-2010, 19:00
AKA: David Yanoshak
I would double check the cable going between the Black Jaguar and the second Jaguar. If the pins don't go 1 -> 1, 2 -> 2, and so on then you won't get communication.
-David
Unread 31-01-2010, 08:53
Kingofl337's Avatar
AKA: Adam
If I hold the connectors side by side it looks like this.
[FTC]: Slow Down Max Speed!! JohnFogarty FIRST Tech Challenge 10 16-11-2009 13:24
Speed control for Jaguars? BurtGummer Technical Discussion 4 13-02-2009 04:47
Jaguars Slow Yellow Blink - Possible Control System Issue MikeDubreuil FRC Control System 3 26-01-2009 23:04
Could FIRST be updating there website it is running extremely slow. Mr.G Chit-Chat 3 01-01-2005 21:22
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
