Go to Post Meanwhile I'm over here with with my completely see-through poly-carbonate blocker prototype laughing. - JohnFogarty [more]
Unread 30-01-2010, 17:51
Robopanda6 Robopanda6 is offline
FRC #2477
Robopanda6 is an unknown quantity at this point
Re: Feeding the Watchdog
Thank you for the advice but...
I've tried your way of setting up the feed but it doesn't work. I tried the way the PDF you sent me did it before your way of doing the watchdog feed but it still didn't work then either. Is there any way else anyone can suggest?
"They say the struggle only sweetens the success"...I guess that's why I stayed in Robotics.
pic: WAI: Packbot feeding salad to FIRST Mentor@ NURC Moheeb698 Extra Discussion 3 19-10-2009 01:52
Watchdog darty NI LabVIEW 8 16-02-2009 09:11
Watchdog Barchechath Programming 6 10-02-2007 20:05
Ball Feeding Tube Legality phrontist Rules/Strategy 4 13-02-2006 22:30
Goal feeding ball mechanism????? Rob Kelly Technical Discussion 2 03-02-2002 23:28
