Go to Post Set your goals as high as your team thinks they can achieve (drafted, drafting, win awards, regional champs, world champs, etc) and go for them. Let the chips fall and have no regrets. - BPetry234 [more]
Unread 30-01-2010, 12:50
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
Solenoid PWM?
Our team did not use pneumatics last year, so I am unsure how to connect solenoids with the new controls system.
(We are not using the 24 volt solenoids in the kit, we are using 12 volt, this may affect set up)
1) I am assuming that we connect to a spike relay again (please correct if I am wrong)
2) Where do I connect the PWMs?
-Digital Sidecar with PWMs for motors?
-special place on the CRIO modules?
If anyone could help that would be amazing! I just remember how to do it with the old controls.
Thanks so much!
Unread 30-01-2010, 12:52
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: Solenoid PWM?
Solenoids, starting last year, connect directly to the Solenoid breakout for the cRIO, which supplies both 12v and 24v.
Unread 30-01-2010, 12:53
AKA: Brigid
FRC #2081 (Icarus)
Re: Solenoid PWM?
Is that an adapter for one of the modules such as the analog break out board for CRIO?
Unread 30-01-2010, 13:02
AKA: Brigid
FRC #2081 (Icarus)
Re: Solenoid PWM?
or can I just connect the solenoids to the relay ports on the digital sidecar as we did with the old controller?
Unread 30-01-2010, 13:39
pschre's Avatar
pschre pschre is offline
Teacher Coach
AKA: James Schreiner
FRC #0806 (Brooklyn Blacksmiths)
pschre will become famous soon enoughpschre will become famous soon enough
Send a message via AIM to pschre
Re: Solenoid PWM?
My team is also interested in the answer to this question.
We are using 6 double solenoids so after using all the ports on the Solenoid Breakout we have 2 un-wired.
Is it legal to power them the pre-cRIO way, Spikes off the power distribution board?
"In this life we cannot do great things. We can only do small things with great love." -- Mother Teresa
"You give yourself to us, O Lord, then selfless let us be, to serve each other in Your name, in truth and charity." -- Robert E. Kreutz, You Satisfy the Hungry Heart
"You have the right to work, but for the work's sake only. You have no rights to the fruits of work. Desire for the fruits of work must never be your motive in working. Never give way to laziness, either...Work done with anxiety about results is far inferior to work done without such anxiety, in the calm of self-surrender...They who work selfishly for results are miserable." -- from the Bhagavad Gita, quoted in Educating Esmé
Unread 30-01-2010, 18:02
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Re: Solenoid PWM?
Thanks so much!
1. The compressor is attached to the spike relay for turning on and off. You will need the electronic pressure switch to have the automatic shut off once the pneumatic zone reaches 115/120 psi.
The solenoids (ex. FRESCO, SMC) connector (two pin female) should be connected to the solenoid breakout on the cRIO (slot 7 or 8).
2. Are you talking about regular PWM cables? They go to the Digital Sidecar. The ones for the motor controllers go the the PWM side. Spike relays go to the Relay "zone". Some sensors go to the Digital I/O "zone". The cRIO modules, (ex. Analog Breakout) takes a PWM cable for certain things, such as the potentiometer (I believe).
I believe that you can put another cRIO module in slot 7, and then have another solenoid breakout there. You might want to check the rules on that though...
Hope this helps.
Unread 30-01-2010, 19:24
Re: Solenoid PWM?
Choices, choices, choices...
For solenoids:
  • Solenoid Breakout (s) on cRIO Solenoid Module(s) in slots 7 and/or 8. Only one of these can be wired as 24v. Both can be wired as 12v. Each Solenoid Breakout is either all 12v or all 24v.
  • Spikes connected via PWM to the Relay output(s) of a Digital Sidecar.
Mix and match as you need for a potential total of (8) 24v coils-a single solenoid or one side of a double solenoid. You can potentially have up to (48) 12v coils.
Unread 30-01-2010, 20:48
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Solenoid PWM?
I count 32 (8 for slot 8, 8 for slot 7, 8 for each of two digital sidecars) What did I miss?
Not that I'm planning on using even 32 coils...
Unread 30-01-2010, 20:53
Re: Solenoid PWM?
So soon we forget.
One relay can support two coils each, so 8 relays...16 coils.
I suppose we need to leave one for the compressor, but I didn't want to sound the purist.
Unread 30-01-2010, 20:55
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Solenoid PWM?
Oh poop, that's absolutely correct.
yes, how soon. Must be old age or something...
Unread 30-01-2010, 21:01
Re: Solenoid PWM?
Now if I were a purist I'd have to admit solenoids are fairly unlimited too.
<R49> Each power-regulating device (speed controller or relay module) shall control one and only one electrical load (motor, actuator or compressor).
A. Exception: Multiple low-load, pneumatic solenoid valves may be connected to a single relay module. This would allow one relay module to drive multiple pneumatic actions.
Solenoid Help aznbadboixx Pneumatics 0 15-02-2008 15:53
single solenoid seanl Pneumatics 4 18-02-2007 02:32
Solenoid control Grizzlie Programming 4 16-02-2005 17:35
24 Volt Solenoid? Stephen Kowski Pneumatics 2 27-01-2005 11:44
double solenoid gail OCCRA 0 11-10-2002 19:42
