Go to Post Crushing the box makes it much easier to think outside the box. :D - Matt C [more]
Unread 30-01-2010, 11:54
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
cRIO Timeout
When we run any code on the cRIO it always comes up with a watchdog error. The code still runs but every 1.5 to 2 seconds the light will blink. The drivers station says "Watchdog Expiration: System X, User Y. X and Y both represent numbers.
Anyone know what the problem is?
Unread 30-01-2010, 18:05
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: cRIO Timeout
The watchdog error is due to a bug when switching between the different tabs on the driver station. You will probably have better luck if you run a search on the error next time before posting. A search for watchdog expiration results in multiple results:
http://www.chiefdelphi.com/forums/sh...g+expirati on
Unread 30-01-2010, 18:06
kgzak's Avatar
AKA: Kris
Re: cRIO Timeout
The watchdog times out even when not switching tabs. Even on the old drivers station we still have issues.
We are using LabView to program and on the new driver station (classmate PC) it says teleop enabled were it should but the light will flash every once in a while. The code still runs.
Unread 30-01-2010, 18:47
OSU_Springer OSU_Springer is offline
Babcock & Wilcox - Engineer
AKA: Bill Springer
FRC #0677 (Murphy's Outlaws)
OSU_Springer is an unknown quantity at this point
Re: cRIO Timeout
Our team is having a similar issue. Even when deploying the "virgin" framework to the cRio, we still have the Watchdog Expiration issue. When the DS is left on the Diagnostic tab there is a never-ending cascade of errors. What is interesting is that the errors slow down in frequency when the vision system is disabled.
Open for ideas on troubleshooting...
Unread 30-01-2010, 22:51
Re: cRIO Timeout
By the way, the Robot Status Light is supposed to blink. When the robot is enabled, it turns off briefly every second and a half.
Unread 31-01-2010, 00:22
kgzak's Avatar
AKA: Kris
Re: cRIO Timeout
Ours slows down and blinks twice really fast and then is solid for the second or whatever. When we use the old drivers station for robot mode it says Watchdog. I will look at the it again monday and tell you what I find.
WatchDog Timeout popo308 Programming 3 22-02-2009 22:04
error 5101 : Timeout Wynlyndd LabView and Data Acquisition 3 31-01-2006 14:05
Timeout!! Ricky Q. Rules/Strategy 19 01-04-2004 22:03
Microsoft Timeout AJ Quick Regional Competitions 12 09-03-2003 17:38
Timeout Ruling Discussion ram Off-Season Events 4 29-11-2001 13:38
