Go to Post I like drifting, but I have to go WRC. Putting a car where it doesn't belong feels right, like combining together drill motors and power window motors and putting them on a big patch of carpet. - Billfred [more]
Unread 30-01-2010, 17:43
mnajork's Avatar
mnajork mnajork is offline
Team Captain
FRC #0008 (Vikings)
mnajork is just really nicemnajork is just really nicemnajork is just really nicemnajork is just really nicemnajork is just really nice
CNC / TIG Welding Problems
It seems that the RF produced by our TIG welder interferes with our Tormach PCNC mill, causing the spindle to erroneously spin up even with the e-stop on, as wells as causing flickers on the screen attached to the computer and various random programs opening up. Obviously, this is a problem when trying to machine something. And suggestions to solve the problem? A faraday cage around the electronics box of the Tormach possibly?
In carpentry there's a saying: "Measure twice, cut once." Oil drillers used to have a similar saying: "Darn measurements, let's rock."
Unread 30-01-2010, 18:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: CNC / TIG Welding Problems
Are you doing AC tig welding? That's usually the culprit... see if you have a high-frequency adjustment on the welder and turn it down. Or try welding with a "soft" AC arc, not a square wave of anything fancy. It's the high-frequency waves used to make square and triangle welding waveforms that screw up electronics.
Unread 30-01-2010, 19:14
DonRotolo's Avatar
Back to humble
FRC #0832
Or give Tormach a call, perhaps they know of a way to help avoid that.
Also, as James notes, square waves produce RF energy well into the several MHz range. If you can avoid them, do.
Distance helps, as field strength decreases by a cube law.
Make sure both the TIG and the Tormach are well-grounded, ideally with an RF ground in addition to the safety ground (which may be useless at RF)
Unread 30-01-2010, 21:44
Gdeaver Gdeaver is offline
FRC #1640
I had a conversation with another of our mentors on Thursday kind of talking about this kind of problem. It may have more to do with the way the machine is grounded. You may want to look at the CNC's installation and wiring diagrams. Many manufactures want a dedicated earth ground right at the machine. This seams to really bother electricians and and many times problems like this happen because of grounding issues.
Unread 31-01-2010, 02:14
AKA: Dr. Brooks
no team (WRRF)
Maximize the distance between the TIG welder and the CNC equipment.
Connect the work piece directly to a good earth ground near the location
where the welder "ground clamp" is connected to the work.
Try and line up the welder ground cable with the torch cable to minimize RF radiation.
On the CNC equipment, encase all cabling in grounded shielding to minimize RF pickup from the welder and install a choke on the power input of the CNC electronics.
Adjust the spark gap on the welder to produce the minimum voltage needed to stabilize the arc.
Ultimately, if you can't provide the needed isolation you have to power down the CNC equipment when running the welder. These two pieces of equipment are not very compatible.
Eugene
Unread 31-01-2010, 14:03
Dick Linn's Avatar
no team (Synergy)
"...spin up even with the e-stop on..."
That is very scary. What else on the Tormach can be turned off during normal operation? What do you do when changing tools?
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 31-01-2010, 14:09
I have to back up Gdeaver on this. In general, electricians do not see a need for signal ground when a safety ground is in place. The welding machine can develop signal across the ground line that may be common to both machines.
Unread 31-01-2010, 15:39
Dick Linn's Avatar
no team (Synergy)
The manual for our old Syncrowave 250 has a whole section on special grounding for HF for anything in a 50 foot radius, including these items:
welding table
work lead
welder case
disconnect box
metal garage door tracks
cover all windows and doorways with grounded copper mesh
water pipes
electrical conduit
metal building panels
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
EMC linux + CNC mill + CNC Lathe Leav Technical Discussion 8 09-11-2008 23:08
TIG Welding Problems cobrawanabe1699 Technical Discussion 21 03-11-2008 13:51
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
Welding Aluminum MIG or TIG? Arkorobotics Technical Discussion 15 01-02-2007 13:17
SCRRF - TIG Welder Redhead Jokes Southern California Regional Robotics Forum 4 10-01-2003 13:11
