Go to Post Dave's grammar is broken. - Madison [more]
Unread 30-01-2010, 10:52
peter1626 peter1626 is offline
FRC #1626 (Falcon Robotics)
peter1626 is an unknown quantity at this point
Signal light not working
We have tried searching CD for this topic but we still can not fix our signal it does not blink. The little lcd on the digital sidecar does not blink either. We have deployed new code and reformatted the cRIO and deployed code again but it still does not blink. Can anyone help? Has this happened to anyone?
Unread 30-01-2010, 11:57
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
Re: Signal light not working
How are you powering the Digital side car? Last year we powered it with 5 volts instead of 12. It all looked like it worked but we had a lot of issues one of which is exactly what you are describing.
Unread 30-01-2010, 20:55
In addition to wiring power from a 20-amp circuit on the Power Distribution board, do you have the big 37-pin connector on the Digital Sidecar cabled to a module installed in Slot 4 of the cRIO?
Unread 31-01-2010, 20:13
yes
Unread 18-02-2010, 17:15
Please see this thread
2010 SBPLI Long Island-Regional-Imagery Award in honor of Jack Kamen
2011 New York City Regional-Industrial Design sponsored by General Motors
2011 SBPLI Long Island Regional-Regional Winner
Unread 20-02-2010, 10:57
LavaEagle LavaEagle is offline
FRC #2660
LavaEagle is an unknown quantity at this point
I had a similar problem a while back what we did to fix:
1. Check for power cables weren't mixed up or reversed.
2. Module on Crio was in right slot and the Serial cord was securely put in the side car and the module
Robot Signal Light Magnechu Electrical 4 14-02-2009 15:17
FRC Signal Light railerobotics Programming 1 07-02-2009 17:01
Signal Light DustinB_3 Electrical 10 21-02-2007 13:10
Robot signal light 11Mort11 Regional Competitions 11 19-02-2007 10:46
Another team's robot signal not working zeep25 Control System 2 25-02-2004 23:33
