Go to Post Our robotics lab has been closed for two days, TWO DAYS! :ahh: - Kevin Selavko [more]
Unread 30-01-2010, 22:22
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
How Precise and Accurate is the Analog In on the Crio?
My team and I have been discussing novel ways to measure the right amount to pull our shooter back. One of the things that was brought up as a neat possibility is a strain gage. We can get a strain gage that is temperature compensated for aluminum, and the wheatstone bridge we have can be powered by the 5 volts, however the return voltage from a strain gage is very small - in the millivolt range.
I'm concerned that:
#1 The Crio won't be able to accurately measure values that small repeatably
#2 The strain gage will be affected by the jostling and slamming around that will result when we put it on our shooter.
Can someone chime in on the Crio resolution and accuracy? (Perhaps Eric?)
How to connect the Workbench with the cRIO? kentschool C/C++ 3 28-12-2009 16:03
How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes brreadd Pneumatics 3 20-11-2009 15:35
how to transfer the program to the crio? beefy1 Programming 5 04-01-2009 10:04
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
