Go to Post when things start to get a little stressful, "FIRST: Fun Is Required. So Tolerate!" - Rich Kressly [more]
Unread 30-01-2010, 22:23
Re: Wireless bridge issues
Originally Posted by sp33chy View Post
I am following the manual to set up the wireless bridge. I can access 192.168.1.250 and get to the login screen, but the credentials do not work. It worked once (kind of, i was able to get to the next page) but it kicked me back to the login page. Tried accessing with both a static and DHCP, router and direct connection. No idea on what to do. Please help
When we set up our control system this year, I tried for nearly an hour to configure the WGA. It wouldn't accept the username and password. I finally got desperate and used Internet Explorer instead of Safari...and it worked.
Try using IE as the web browser if you're not already.
Unread 01-02-2010, 21:05
sp33chy sp33chy is offline
FRC #3332
sp33chy is an unknown quantity at this point
Problem fixed. I decided to screw the instructions and follow my way. What I did, if anyone is having similar issues:
1. Set up the router with a static IP (10.33.32.4 for me)
2. Wire the bridge to the router and the router to the pc.
3. Run the install CD for the bridge, do the one touch wifi link thing it tells you not to do in the directions... You should now have the bridge wirelessly connected to the router. Plug bridge into crio.
4. Change PC IP and all back to static and what not. And bam it should work.
wireless bridge problems tanguma26 Programming 8 31-01-2010 11:16
Wireless Bridge Problems furiousgeorge Control System 9 28-01-2010 13:28
Where to purchase Wireless bridge on Robot Yuan Xue Lim Kit & Additional Hardware 6 20-01-2010 15:00
Help connecting wireless bridge cactuarman Control System 4 24-03-2009 14:24
Source for Wireless Bridge Gary Bonner FRC Control System 1 07-01-2009 20:57
