Go to Post Our role models are practical visionaries. That's the glue. - JaneYoung [more]
Unread 21-01-2010, 18:15
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Code not loading properly
We can now connect via Remote System but still get "No Robot Code"
Unread 22-01-2010, 12:00
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
did you do a (right click on project)>Run Kernel task...?
Watchdog.Kill();
Unread 22-01-2010, 14:41
Steve Warner Steve Warner is offline
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
When you reimage the cRIO, make sure you select the type of software you are using. We were trying to help another team that had imaged their cRIO for LabVIEW. When we downloaded C++ code, everything looked good but we got the No Code message.
Unread 30-01-2010, 23:54
BLProgram2010's Avatar
BLProgram2010 BLProgram2010 is offline
FRC #2534 (Robo Lake)
BLProgram2010 is an unknown quantity at this point
We're use Labview. Every time we develop new code and try to deploy it or connect to the cRIO, there a error that says the vi's in the start up application will not open and will remain closed if you continue to apply and deploy. I found out the by using the 'cRIO Imaging Tool' and hitting 'Format controler', the pproblem is removed and we can deploy the code and run a drive test. But when we switch users back into the developer the same problem occurs and the cRIO needs to be re-imaged again. Running the 'cRIO imaging tool' with the format controler takes about seven minutes to finish; and ontop of that we still need to deploy and build the code which take another five to seven minutes. We seem to be spending a lot of time re-reimaging the cRIO to fix our problem. How do we fix it?
Unread 31-01-2010, 01:11
Originally Posted by BLProgram2010 View Post
We're use Labview... How do we fix it?
Please don't post the same question in multiple places. It won't get you answers any faster. (The C++ subforum is not a good place for a LabVIEW discussion anyway.)
Laptop is not finding the cRIO properly? Studentish Electrical 4 07-05-2009 12:03
1 joystick controls not turning properly andrew_4_life Programming 4 28-03-2008 01:22
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
Pictures not loading sanddrag CD Forum Support 32 11-10-2002 01:55
