Go to Post It's easy to get overwhelmed. Don't get overwhelmed, just keep working at things a little bit at a time. (Oh, and don't forget to have fun!) - DominickC [more]
Unread 31-01-2010, 02:06
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
EMERGENCY GEAR NEEDS
we seem to have backed ourselves into a bad corner
Our gear supplier sent us 1 out of 2 sets of gears we need. They said both shipped on time, but we where informed AFTER that the other is on backorder...till when?.....MARCH 8 at the EARLIEST!
Now that everything is designed around those gears we really dont want to redo all our water jetted parts.
Custom gear manufactures want anywhere between $300 to $1000 for the 2 gears...
Hoping you guys now of a supplier that stocks gears and shipps em fast! thanks! BTW, SDP-SI is the company that is on backorder
Unread 31-01-2010, 02:08
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: EMERGENCY GEAR NEEDS
What sizes are you looking for along with pitch?
-RC
R.C.
MadTown Robotics Team 1323
Unread 31-01-2010, 02:10
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
In order to help you find the gears you are looking for you will need to provide some information on the gears.
-Number of teeth
-Pitch
-Pressure Angle
-Any specific bore needs?
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
-RC
Hubless Spur
DP-24
54 tooth
Pa-14.5
bore .375
face .25
thanks
Unread 31-01-2010, 02:18
R.C.'s Avatar
http://wmberg.com/
P24A21-54
I found about what you were looking for except you have to bore it out bigger on the lathe. I'm pretty sure all that matters is spacing between the gears. You may have to do some extra work with this gear.
Also can you please avoid the all caps title next time. Everyone has an emergency time to time, your answer won't come any faster than it normally would.
Thanks,
-RC
R.C.
AKA: Dave
Have you considered changing both gears in that reduction to something that gives you a similar ratio without changing the center to center distance? It might be easier to change two gears to a different pitch or number of teeth than to to re-do the water jetting.
Just a thought.
Unread 31-01-2010, 02:23
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
Just a thought.
yes, that was what i was going to tell my kids tomorrow after some research. They will moan and gripe...but worst case i aint paying $150 for a gear lol
Unread 31-01-2010, 02:37
AdamHeard's Avatar
Lead Mentor
We actually bought a whole pinion rod in that size from sdp-si two weeks back, if we didn't part it all off (we shouldn't have), we may be able to fab some for you. Shoot me a pm with the sizes and bores you'd like, and I'll check in the morning if we can amke it happen.
Unread 31-01-2010, 04:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
SDP is notorious for having stuff out of stock that takes weeks to get restocked.
It's like they only keep 2 of each gear in stock at a given time or something...
2001-2004: Team 100
2006-Present: Team 254
Unread 31-01-2010, 07:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Sounds to me like you need a Martin S2454 http://www.martinsprocket.com/2001/SecGa.pdf#G24
You'll have to turn or mill the hub off if you really do need it hubless.
Try your local Motion Industries to order it. They usually get them in a couple days.
Unread 31-01-2010, 15:38
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
If you guys find a gear and need it machined we can do it for you up in Suwanee. Just let me know if you need anything.
Mentor 2415
Unread 03-02-2010, 11:07
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
thanks to all. SDPSI suddenly "got them in stock" and dosent know why we were told march 8th......nuclear war adverted
Unread 03-02-2010, 11:11
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Somehow they still havnt gotten us our back ordered ones even though they shipped us new ones we ordered sepratly almost 2 weeks later.... Thanks for the offers to help though, we appreciate it!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
New team needs help with gear tooth sensor zako234 Programming 2 30-01-2008 23:43
Emergency feliks_rosenber Rules/Strategy 10 23-02-2007 15:26
worm gear emergency ClicheCow Technical Discussion 5 21-02-2005 01:39
VIZ Emergency Jeremiah Johnson Inventor 4 22-01-2005 19:55
Emergency Team 25 Needs Help Keith Chester Technical Discussion 19 25-02-2004 21:35
