Go to Post Don't you just wish life had a redo button? - DHarris [more]
Unread 31-01-2010, 05:58
SteveGarward's Avatar
SteveGarward SteveGarward is online now
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Error connecting to cRIO through Windriver
Hi
I've been trying on and off to get Workbench connected to the cRIO for debugging and console output. Each time, it fails to connect and gives an error, largely along the lines of the image on the cRIO is not the same as the image locally (or some such - sorry, I'm not in front of it right now).
So it's not a link error (symbols out of date etc.).. This is just basic connection to the cRIO. I've applied all the updates, and re-imaged the cRIO to v19 (twice, for various reasons). I've followed the instructions in the getting started guide exactly.
Does anyone else have any suggestions? This seems to work for everyone else first go.
The only thing that occurred to me tonight, while reading other posts, is that perhaps we need to have the Console Out DIP switch on the cRIO set to on. Is that the part I'm missing?
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 31-01-2010, 07:59
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Error connecting to cRIO through Windriver
Could you please try setting 'Bypass checksum comparison' in the Target Connection properties and see if that allows you to connect?
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 04-02-2010, 06:54
Got this working tonight. Honestly don't know why it suddenly worked... All updates were applied before, and it didn't work with or without those updates.
I selected a new kernel image file - different location to where it was previously, I think after the latest workbench update was applied.. But either way, with that now it all seems to work ok.
Connecting to Download code in WindRiver ExarKun666 C/C++ 8 04-02-2010 16:13
WindRiver not connecting to robot mika.perlin C/C++ 0 27-01-2010 21:48
connecting to Crio using windriver Tds123 Programming 1 27-01-2010 13:21
Connecting to the cRIO lingomaniac88 Programming 1 30-01-2009 10:58
3pin RS232 port doesnt work on camera. can't debug while connecting through the DB9. Leav Programming 2 30-12-2007 11:44
