Go to Post Life is totally random and there's nothing you can do to change that. - kristen [more]
Unread 31-01-2010, 09:15
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
camera - console error messages
Still not got the camera to send a single frame to the Dashboard. In the Task..console we see these messages:
[CameraToDashboardExample.cpp:RobotMain@0046] DEBUG Waiting for camera to initialize
[CameraToDashboardExample.cpp:RobotMain@0050] DEBUG Starting image server
[CameraToDashboardExample.cpp:RobotMain@0052] DEBUG Image server Running
task 0x1eb0240 ((FRC_PCVideo) deleted: errno=0 (0) status=0 (0)
Should the FRC_PCVideo task be getting deleted?
After about one minute, the Image server stops and then the console fills with this line, repeated quickly and forever:
bind: S_errno_EADDRINUSE
The Driver Station classmate is at 10.xx.yy.5, with Remote Dashboard set to 10.xx.yy.6. The PC at 10.xx.yy.6 is running the Dashboard and is also the Windriver platform. It is the newest Dashboard with the compass in the lower right. The cRIO has C++ v19 loaded. The camera has the FRC/FRC and root/admin accounts, IP 192.168.0.90. We get camera images to the web page when we connect the camera direct to a PC. After the camera boots, its led's go green. We use the orange crossover cable from camera to cRIO port 2.
Anyone got some suggestions what could be wrong? We've been tinkering with the camera code now for 2 weeks.
EDIT - the Windriver PC is running Windows 7. Anyone successfully running C++ camera code to dashboard with Windows 7?
camera and console a kenny03 Java 4 26-01-2010 21:47
Camera Error Number kevin51292 Programming 3 07-12-2009 21:48
Error -1074396080 camera trouble Kahn! NI LabVIEW 1 16-02-2009 12:24
Camera error message Slick NI LabVIEW 1 25-01-2009 11:34
Camera pointing error? Craig Putnam Programming 14 21-01-2006 02:52
