Go to Post On the contrary, you've had several helpful responses. You might be confusing "helpful" with "do my homework for me." - Rick TYler [more]
Unread 31-01-2010, 00:41
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Ball out of Bounds Penalty
Say a team goes up to score at a goal but there kicker is powerful enough to go from one burm to another and kicks it into the goal and it bounces/flies out, would that be a ball out of bounds penalty?
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 31-01-2010, 00:56
Re: Ball out of Bounds Penalty
If the ball does not leave the field, there is no penalty. If you're near the goal kicking like that, there is a net next to the field to block missed shots into the field, as well as memory foam to dampen the impact.
If you miss once or twice while obviously kicking a goal, and it goes out, you probably won't get any penalty (other than the standard ball-at-midfield return method delaying your next shot). If you do it repeatedly, expect the refs to pay special attention to you (penalty and yellow card for <G19>, and/or a possible <S01> for repeatedly endangering field personnel--<S01> carries a penalty, disablement, and a good chance of a trip back to inspection to correct the unsafe operation).
If you're talking having it bounce out of the corral area, you may want to slow it down anyway--it may or may not fall into the category I outlined above, and you don't want to run the risk of a delay-of-game penalty due to not being able to get to the ball fast enough.
To be on the safe side, have a "low-power" shooting mode for the near zone.
Unread 31-01-2010, 10:29
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Originally Posted by dodar View Post
... burm ...
Dude - It's a "berm", not a "burm" - Blake
Unread 31-01-2010, 10:38
dodar's Avatar
Does it matter? you knew what i was talking about anwyays
Soccer Ball Sold Out topgun General Forum 72 06-03-2010 23:18
Ball Bouncing Out of Bounds? Justin Ridley Rules/Strategy 26 25-03-2008 23:55
Placing Tetras out of bounds Someone Rules/Strategy 6 10-01-2005 00:08
Knocking out Doubler Ball mightywombat Rules/Strategy 47 23-02-2004 15:18
Out of bounds... -- copy of posting in General archiver 2000 0 24-06-2002 00:11
