Re: Digital IOs scrambled on Dashboard
We had the same problem. If you print out the value in hex that is being sent to the DS you'll see what is going on. Writing from memory, the two rightmost bits are not used. The third bit is point 14, the fourth is point 13, etc. I might have this backwards but it's something like that. We shifted the bits right two places and then shuffled the bits so they wound up in the right place. A good example of bit shifting to show the students but another bit of "sample" code that doesn't work. If you need more detail on this, let me know.
| Digital IO in C++ | EricGoodchild | C/C++ | 3 | 01-15-2009 11:05 PM |
| Labview Dashboard and updated IFI dashboard spec | Joe Ross | LabView and Data Acquisition | 1 | 04-04-2006 02:04 AM |
| Digital Caliper as a Digital Readout on Small Mill | sanddrag | Technical Discussion | 9 | 10-13-2005 10:51 PM |
| 2004 Dashboard Protocal vs 2005 Dashboard Protocal | Kyle T | Programming | 4 | 03-14-2005 10:19 PM |
| Digital videos | archiver | 2001 | 1 | 06-24-2002 03:57 AM |
