Go to Post Gracious professionalism dictates that if you come to play, I must help you. - Al Skierkiewicz [more]
Unread 31-01-2010, 11:51
kick3nitx360 kick3nitx360 is offline
AKA: Dave.
FRC #1626 (Falcon Robotics)
kick3nitx360 is an unknown quantity at this point
Send a message via AIM to kick3nitx360
SERVO NOT WORKING
I have the servo plugged into the correct place, and have tried the LabVIEW sample code but i cant get the servos to turn. Can someone please help?
Unread 31-01-2010, 11:53
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: SERVO NOT WORKING
Did you place a jumper across the two pins on the Digital Sidecar right next to the PWM port the servo is plugged into? This jumper is necessary to power the servo and will need to be in place for it to work.
Unread 31-01-2010, 12:04
AKA: Dave.
thanks we got it to work
Unread 31-01-2010, 18:49
chsrobotics3283's Avatar
chsrobotics3283 chsrobotics3283 is offline
FRC #3283 (Clarksburg Robotics)
chsrobotics3283 is an unknown quantity at this point
where you using the Servo Example. vi? Because I need some help on that
Unread 03-02-2010, 11:20
peter1626 peter1626 is offline
peter1626 is an unknown quantity at this point
I'm another programer from 1626 and yes we were using the Servo Example.vi, what do you need help with? we would be happy to help
Unread 03-02-2010, 17:12
so far our robot is able to rotate to target.
is there anything else that the servo should be able to do?
is the camera itself supposed to move?
Unread 03-02-2010, 17:32
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Unless you mean the camera is moved by the servos, then no the camera does not move. Actually, depending on where you place the camera, you probably need no servos at all to aim the camera.
Kettering Motorsports
Unread 03-02-2010, 17:37
ok thanks, then Im all set. But I do have one more question for the electrical board. Do you have any suggestions on what type of material I should use? Right now we are on wood, but we also bought Lexan. Is it a good idea to mount everything on Lexan? And do you have any suggestions to make the electrical board compact and clean (as in not messy with length wires) ?
Unread 03-02-2010, 18:06
apalrd's Avatar
More Torque!
VRC #3333
Generally, we mount all of our speed controllers (mostly Victors but some Jaguars) on perforated aluminum mounted in the frame. We generally use folded sheet metal chassis, so we would make the bottom of about half of it out of perforated aluminum and mount everything on that. The cRio should be mounted on lexan or wood to be electrically isolated, but nothing else needs to be isolated. I'll see if I can find pics of it on old robots...
http://jasonjmonroe.com/TWMM/photos/...d/P2149916.jpg - Buzz14 (2009) Jaguars in chassis sides, with PD board in middle.
http://jasonjmonroe.com/TWMM/photos/...d/P2149918.jpg - Better picture of how we fit the Jaguars in.
http://jasonjmonroe.com/TWMM/photos/...d/P2149898.jpg - Top view of chassis. The PD board is located to the right of the battery, slightly out of sight and hidden.
http://jasonjmonroe.com/TWMM/photos/...d/P2149900.jpg - cRio and DSC mounting, where they fit in the frame. the cRio is mounted on polycarb.
If we didn't have a ball manipulator system in the middle of this robot, we would've put a sheet of perforated aluminum in the middle area and put all of the Jaguars there.
A direct answer to your question is to use perforated aluminum with polycarb for the cRio.
Our website is being redone so I can't find any older pics at this time, but in most of the robots we had a rectangle with two side rails (inner and outer, basic 6WD chassis) out of folded sheet metal, with a divider in the middle. In the middle, one half would have a sheet of perforated aluminum on which all of the electrical components would be located, the other half would have the battery, drive motors, and some bot-specific items. We used this basic design from 2006-2008, and something similar but welded in 2005.
Unread 03-02-2010, 18:32
Thank you for the pics, they were really helpful, I am planning to mount the whole electrical board on lexan actually.
[FTC]: Motor and Servo configurations aren't working FTC Mesa Prep FIRST Tech Challenge 5 09-12-2009 10:20
Servo not tracking... AG-chadd Programming 2 06-02-2009 16:15
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Subscriptions not working? Jeff Waegelin CD Forum Support 2 07-02-2007 14:11
