Go to Post bump. - connor.worley [more]
Unread 31-01-2010, 13:56
Blarglefish1255 Blarglefish1255 is offline
FRC #1255
Blarglefish1255 is an unknown quantity at this point
Jaguar to Motor
Do we have to have a seperate jaguar for every motor? We plan on using two twin motors for each wheel. Each set of twin motors are attached to one gearbox.
Unread 31-01-2010, 13:59
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: Jaguar to Motor
You may only power one motor off of one speed controller. (Jaguar)
However, if you want to power two motors off the same signal, you could use a Y-Cable from the DSC, if you are using PWM control.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 31-01-2010, 14:15
Re: Jaguar to Motor
<R49> Each power-regulating device (speed controller or relay module) shall control one and only one electrical load (motor, actuator or compressor).
A. Exception: Multiple low-load, pneumatic solenoid valves may be connected to a single relay module. This would allow one relay module to drive multiple pneumatic actions. No other electrical load can be connected to a relay module used in this manner.
Unread 03-02-2010, 10:30
Mike9966's Avatar
Mike9966 Mike9966 is offline
Mentor Mike
FRC #2846 (Fire Bears)
Mike9966 is an unknown quantity at this point
Re: Jaguar to Motor
So, on this Y cable idea. I tried this past weekend to run 2 Jag's from one pwm output and anytime I plugged in the second Jag, neither would work.
I ended up being able to only run 1 motor for the test because of it.
Are we sure the 1pwm to 2 Jags via a Y cable is supposed to work?
Thanks
Mike
Do the best you can! Always
Go FireBears
2009 10000 Lakes Finalists, thanks 2825 & 2177
2010 10000 Lakes quarter finalists
2011 Duluth and 10000 Lakes
2012 Superior, and 10K Lakes, Qt finals, MRI
2013 Northern lights, 10K Lakes-Semi finalists, MRI, River Rendezvous, Minne Mini
2014 Northern Lights, 10K Lakes
Unread 03-02-2010, 11:03
Re: Jaguar to Motor
Thanks
Mike
1 PWM port can provide signal for any one of the following combinations:
  • 1 Servo
  • 1 or 2 Victors
  • 1 or 2 Jaguars
You can not have one PWM port provide signal for a Jaguar and a Victor. The Victor draws much more signal current than the Jaguar and essentially starves it.
I made sure that a single PWM port can provide more than enough signal current for two Jaguars always. In fact, the circuit is beefy enough for three (or four >80% of the time) Jags.
Can I ask which PWM port(s) you were using? Are you sure you didn't have one of the PWM cables upside down?
Unread 03-02-2010, 11:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Jaguar to Motor
Also are the motors supposed to turn the same way, are they wired the same (red and black to the same connections on both Jaguars and at the power distribution board), etc.? Make sure they are not trying to turn different directions! that would make it not work at all.
Unread 03-02-2010, 16:40
Mike9966's Avatar
Mentor Mike
Re: Jaguar to Motor
This was a case of driving 2 motors in a tough box. Yes, the wiring was the same.
The thing I didn't think to mention was that I was driving them with a radio control (think model car) receiver just so we could test the motors and see how much torque we could get out of them.
I assumed (my bad, I know, lol,) that the inputs on the Jags, or any other device were high z and so that loading wouldn't be a problem.
I see now that that's not the case.
Thanks for letting me know.
Mike
Go FireBears
Jaguar Brandon_L NI LabVIEW 1 21-01-2010 19:49
Jaguar Failure Nightfall831 Electrical 8 21-01-2009 10:12
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
Jaguar Problem Sauce Electrical 7 10-01-2009 14:28
Jaguar Motor Controller Problem prashil27 Electrical 5 07-01-2009 21:21
