Go to Post Success is realizing that anything is possible, persistence is the key. - SlamminSammy [more]
Unread 31-01-2010, 15:13
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
Camera tracking code not working in our own program, but works in CircleTrackerDemo
Our team is able to get the tracking code to work when it is in the CircleTrackerDemo code, but when we put it in our own code along with the other stuff, it doesn't work and we get this error. Any ideas?
Uncaught exception in Thread.run():
[cRIO]     on thread edu.wpi.first.wpilibj.templates.RobotTemplate - main
[cRIO] java.lang.IllegalArgumentException: MIDlet class specified, edu.wpi.first.wpilibj.templates.RobotTemplate, was not found
[cRIO]     at java.lang.Throwable.<init>(88)
[cRIO]     at java.lang.Throwable.<init>(102)
[cRIO]     at java.lang.Exception.<init>(53)
[cRIO]     at java.lang.RuntimeException.<init>(58)
[cRIO]     at java.lang.IllegalArgumentException.<init>(54)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(94)
[cRIO]     in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO]     at com.sun.squawk.Isolate.run(1554)
[cRIO]     at java.lang.Thread.run(231)
[cRIO]     in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO]     in static method #3 of com.sun.squawk.VM(bci=6)
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 31-01-2010, 17:27
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Camera tracking code not working in our own program, but works in CircleTrackerDe
Could be any number of things. Would be nice if we could see the code you are using
Unread 31-01-2010, 19:35
Just figured out stuff. I actually put my code into the trackerdemo code and it worked fine. So now we're good. Thanks though!
2011 Pit Crew:
HYPER Alumni
Unread 31-01-2010, 19:40
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
This took a good whole day for us to figure out, too. I thought there was a way to import the same code into our own program, but I guess not. Anyway, good to know that you've found the answer!
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Code downloaded but not working... :( pudgeball C/C++ 4 28-01-2010 11:04
Camera moving but not tracking ijk90825 Programming 3 31-01-2009 14:40
Camera tracking but not moving penguain NI LabVIEW 9 30-01-2009 10:10
Camera Tracking not working? NinJA999 C/C++ 0 25-01-2009 15:28
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
