Go to Post The bottom line is this program means the world to me ,and the friends i hold dear that feel the same way....I believe it changes lives and outlooks on reality. - D@ve [more]
Unread 31-01-2010, 15:41
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Re: Any way to connect to console on cRIO?
Ahhh... Host shell is basically what I want. I tried telnet-ing but no connection. Didn't know if that was because the cRIO doesn't run a telnet daemon or not.
But for the host shell, I'll need to resolve my other issue where I can't get Workbench connected to it as a remote target.
I also found some posts and documentation around that say I should be able to FTP to the cRIO to retrieve files, which is really what I want. So I will try that today too and report back.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Cannot connect to cRIO from WindRiver Darkknight512 C/C++ 8 25-01-2011 19:42
Cannot connect to cRIO aybose Java 3 02-02-2010 22:20
Default windriver program, no code and warnings on CRIO console out pafwl C/C++ 1 16-01-2010 16:03
Logging console data to text file on crio Kingofl337 Programming 3 09-04-2009 18:57
Problem receiving console output from cRIO Arborama Programming 7 15-02-2009 03:30
