Go to Post And to think, a lot of students are planning parties and celebrations on their last day of school and you guys are recycling trash. - JaneYoung [more]
Unread 31-01-2010, 12:52
dungeonmonkey dungeonmonkey is offline
FRC #2458
dungeonmonkey is an unknown quantity at this point
Question camera wire up to power distributer
Im having an issue hooking he camera up to the power distribution board. On the diagram for power distribution, it shows the camera being hooked up to the 5 V connection on the end of the power distributer. The only problem is that I cannot find the correct connector for this 5 V slot. Originally, I thought that it was a pressure-based slot, but before i got the chance to mess with it, my mentor stopped me and said that he thought there was a connector for it. We have a bunch of connectors that seem to almost fit it (I think they're the 12 V connectors) but just dont seem to. they're off by just so little
Please help. I want to get this camera working ASAP.
Unread 31-01-2010, 13:27
Re: camera wire up to power distributer
The 5v connection on the Power Distribution Panel is actually a built-in gray Wago connector.
There isn't a separate connector for that one.
Just use your small screwdriver on it as you would with one of the other Wagos.
You can see an example in this photo.
Unread 31-01-2010, 18:31
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Please don't feel bad, I spent an hour looking for the connector for that spot a couple months ago when we wanted to hook up the camera on last year's robot. I was sure it was another plug-in. I can attest, that after getting on my hands and knees and sticking my head inside the robot until I could see it, I decided it was indeed an onboard connector and no plug was needed...
At least I didn't have to order a new connector because we lost it!
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 31-01-2010, 22:33
FRC #2458
thanks this helps alot.
Team modo: "I'm sure it's around here somewhere..."
"If at first you do not succeed, you fail." -Glados
camera wire up Armando Programming 4 22-02-2007 08:59
power to the camera masanchez General Forum 1 23-01-2006 20:16
Camera power cable MustangRobotics General Forum 11 12-01-2006 22:39
camera power supply stephenthe1 Programming 21 29-01-2005 21:44
camera power supply stephenthe1 Electrical 21 29-01-2005 21:44
