Go to Post Dedication to FIRST gets more challenging as life gets more complicated but the rewards are SOOOOO worth it! - Sean Schuff [more]
Unread 01-31-2010, 03:56 PM
L337Lobster L337Lobster is offline
L337 Programmer
AKA: Jackson
FRC #0225 (Awesome-O)
L337Lobster is an unknown quantity at this point
Exclamation Run code errors.
When i attempt to run the code to put it on the cRio i get the following:
init:
init:
No to.jar.file specified.
Using "suite\BuiltInDefaultCode_1.0.0.jar"
Deleting directory C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\build
Deleting directory C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite
Deleting directory C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\j2meclasses
clean:
Created dir: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\build
Compiling 1 source file to C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\build
compile:
Created dir: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\j2meclasses
preverify:
Created dir: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite
Building jar: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite\BuiltInDefaultCode_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
Romizer processed 73 classes and generated these files:
  C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.sym
  C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.suite
  C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.suite.metadata
  C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.suite.api
Expanding: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite\BuiltInDefaultCode_1.0.0.jar into C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite
Moving 1 file to C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite
Deleting: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.suite.api
Connecting FTP @10.2.25.2
C:\Users\L337-Lobster\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line:
C:\Users\L337-Lobster\sunspotfrcsdk\ant\upgrade.xml:40: java.net.ConnectException: Connection timed out: connect
BUILD FAILED (total time: 24 seconds)
I cannot figure out as of yet how to go about fixing this.
Unread 01-31-2010, 06:51 PM
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Run code errors.
You can try a few things to make sure everything is ok and then if you get the error. Just keep trying until it goes, it will eventually.
1.) Goto Run -> CMD
PING 10.2.25.2 - You should receive 4 responses of less then 50ms
2.) Next in the same command window type:
FTP 10.2.25.2 - hit enter twice it should log into the FTP on the cRio
then type "ls" this should give you a directory listing of the cRio root
If everything works, try running a cable from you PC to the router and then run your project. If you still have issues run another cable from the router to the cRio directly and try again. This seems to be a issue where the system gives up to easily and effects poor connection and slower computers. We have student using the classmate and it took three tries to get it to download.
We have also seen a issue with the system hanging on "Setting Up for Run" on multiple computers and ended up writing a batch file to copy the image.suite file to the cRio directly.
Unread 01-31-2010, 08:25 PM
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Also, if ftp works from the command line, but doesn't from the run command, make sure that the firewall on the PC is turned off.
can't run code viper110110 Programming 3 09-18-2009 09:25 PM
Errors compiling Kevin's new code (pragmas) Bryan Herbst Programming 11 01-31-2008 12:50 PM
ADC code errors epl692 Programming 2 01-22-2008 12:56 PM
Timers causing code errors? Uberbots Programming 6 01-22-2008 02:10 AM
