Go to Post I have a bobble head? - Koko Ed [more]
Unread 30-01-2010, 21:50
ienjoymycereal's Avatar
ienjoymycereal ienjoymycereal is offline
FRC #2090
ienjoymycereal is an unknown quantity at this point
Mechanum Wheel Rollers Stuck
Our team has 6" mechanum wheels from Andy Mark. However, some of the rollers that are on the wheels are kind of stuck and won't roll very easily. Does anyone else have this problem? If so, are there any quick fixes for it, or does it even make that much of a difference, considering how heavy the robot will be?
Unread 30-01-2010, 21:59
Re: Mechanum Wheel Rollers Stuck
Loosen the screws on those rollers that are stuck.
Unread 30-01-2010, 22:02
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
The more freely the rollers turn, the more consistent your robot will maneuver. We used AndyMark 6" mecanum wheels in 2008 and had no issues with them. We had a spare set as well so no notable problem with 8 wheels.
Since we did not have issues, I'm not sure how much help I can provide. My suggestion is to try loosening the nut/screw on either side of the offending rollers. They may be just a bit tight. If you continue to have problems you may try asking AndyMark directly. They are usually very friendly and helpful.
Unread 31-01-2010, 20:30
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
In '08 we got those wheels. Brought them to the practice field, and within 5 minutes they were bent and a bunch of the rollers were locked. We took the long road: machine new ones out of a block of aluminum As for your wheels, make sure the plates aren't squeezing the rollers.
Unread 31-01-2010, 22:22
baruffir baruffir is offline
Me
FRC #0178 (Enforcers)
baruffir is an unknown quantity at this point
I haven't ever used the 6" ones, but I've had the same issue with the 8" ones. First of all, it does make a significant difference, especially if all the rollers on one wheel are tight, while the other wheels are loose. To fix this, simply loosen up the bolts on the wheels. It will seem like they are too loose, and that the wheel will fall apart, but it actually works quite well.
Unread 31-01-2010, 22:38
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
We had this problem with some pre-season project wheels. All you need to do is loosen the bolts on the tight rollers.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
To those using rollers: Roboham General Forum 11 14-01-2009 02:37
Mechanum Code Kory Programming 0 22-01-2008 18:39
Mechanum Wheels Andy B Technical Discussion 2 10-01-2006 17:41
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
Ball Rollers archiver 2001 8 23-06-2002 23:26
