Go to Post Such is life in the fast-paced, laugh-in-the-face-of-adversity, never-let-them-see-you-sweat, sometimes-you're-the-windshield-sometimes-you're-the-bug world of FIRST Robotics! - Sean Schuff [more]
Unread 31-01-2010, 22:48
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Ethernet cables not 'clipping' into Classmate PC
We should have reported this earlier, but it appears the Ethernet port on our Classmate PC has been partially broken since we opened it. No CAT5 Ethernet cable (we tried a bunch of different ones) will 'click' and stay in the port. Although just an annoyance now, it's gonna be a bigger problem at the regional...
We already took a close look at the port. Did something break off the Ethernet port that we aren't aware of?
Is there an easy fix for this? I'll try getting some photos of the port later.
EDIT: To clarify the "opened" part, I meant since we opened the box it was in, we didn't open the Classmate itself. >_>
Unread 31-01-2010, 23:54
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Ethernet cables not 'clipping' into Classmate PC
Well, this is not a real solution but you could jam something in with the cable. I actually had to do this at a LAN party today since my ethernet cable's clip thing was broken off. I just folded up a small piece of paper and jammed it in.
You could try carefully putting some rubber or foam in there.
"we don't build robots, we build people"
Unread 01-02-2010, 02:15
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
You could buy a USB Ethernet dongle and use that or just use good old electrical tape
Thanks,
timytamy
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 01-02-2010, 10:33
From another thread:
Originally Posted by Mark McLeod View Post
For hardware problems with the FRC Classmate, FIRST has told us to contact the 2gopc help desk directly:
Crio not communitcating with Classmate! voteforandy1 General Forum 1 22-01-2010 21:50
Camera not sending image to Classmate? TPNigl Programming 14 22-01-2010 17:05
Dashboard not appearing on classmate railerobotics Programming 2 20-01-2010 15:42
Classmate not loading Dashbaord on bootup gokul Control System 2 13-01-2010 10:34
PWM cables not fitting GillSt.Bernards General Forum 4 16-02-2009 00:43
