Go to Post I know I exaggerated a bit, but NASA put a man on the moon with less processing than some FRC bots. Think about that for a minute. - JesseK [more]
Unread 30-01-2010, 19:42
nabioullinr nabioullinr is offline
FRC #1073
nabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura about
Gyro Questions
Is the gyro already compensated for temperature, or should this be done manually? Also, what is the difference between the gyro this year (ADW22307) and last year (ADW22305, I think)? I could not find any differing datum between the two datasheets.
Unread 30-01-2010, 20:39
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Gyro Questions
Can't tell you the difference, but the fact that there is a temperature sensor onboard with its own output pin(s) tells me that temperature compensation is likely manual.
Unread 01-02-2010, 00:32
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
Re: Gyro Questions
I doubt that you would have to do it manualy. In any event the temperature difference isn't going to make verry much difference in the acuracy of your readings its not like were competing in vastly different temperatures than you'll be testing in.
Unread 01-02-2010, 10:16
Re: Gyro Questions
The only difference I could find between the two was the offset values in during self test. Since I didn't bring out the pins necessary to perform self test, there is no difference to users (that I know of). In fact, the circuit is also unchanged.
If you want to temperature compensate, you will have to do so manually using the TEMP pin.
Unread 01-02-2010, 14:34
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Gyro Questions
You have to do it manually, and you probably should.
From the sensor manual-
The ADW22307 has an integrated temperature sensor to assist in temperature compensation. Nominal output is 2.5V at 25°C plus 9mV/°C.
So that means that depending on your workspace, temperature could definitely skew things. Plus, arenas such as the ones we find at competition are typically chilly, so you will likely find different gyro readings at competition than at your workplace.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 01-02-2010, 15:37
Re: Gyro Questions
The WPI Robotics Library Gyro routines automatically accumulates the gyro value for a period of several seconds on startup. The rate changes from then on are referenced to this initial baseline value. You only have to worry about temperature compensation if you expect large temperature changes during a single match.
It doesn't matter if the temperature changes between your workspace and the competition as long as the robot is power cycled between those two places.
Unread 01-02-2010, 16:37
Re: Gyro Questions
Thus it would be a good idea not to mount the sensor too close to a source of heat (e.g. a motor).
Unread 01-02-2010, 16:55
AKA: Bryan
Re: Gyro Questions
Ahh, that makes our job easier overall.
However, we are having issues with the gyro not outputting correctly, and we assumed that it had to do with the temperature. Guess its back to troubleshooting. Thanks for the info though!
Gyro Sensor Questions pheadxdll Programming 13 09-04-2008 00:52
Quick Gyro Questions Jake M Programming 5 24-01-2008 22:36
EasyC Timer and Gyro questions TubaMorg Programming 11 09-02-2006 21:19
Gyro Questions Jeff G Control System 8 03-12-2004 19:15
Gyro Sensor Questions sanddrag Electrical 8 27-09-2003 20:58
