Go to Post Injuries can come out of no where. I know this is only a robotics competition but the injury doesnt care where or what you are doing. - nightrenegade00 [more]
Unread 30-01-2010, 16:47
nabioullinr nabioullinr is offline
FRC #1073
nabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura about
Which Compass to Use?
I want to implement a compass in the robot (I understand it is very sensitive to magnetic fields, but I still want to experiment); which compass sensor is recommended?
I couldn't really find any useful info other than the HiTechnicCompass header file (http://www.hitechnic.com/cgi-bin/com...on&key=NMC1034 ?) which seems to have an I2C interface.
Unread 30-01-2010, 16:56
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Which Compass to Use?
The HiTechnic Compass plugs directly into the i^2c port on the digital sidecar. Programming it in C++ with the WPI library is incredibly simple, see program below.
Here's the WPI doc on it:
http://www.virtualroadside.com/WPILi...c_compass.html
#include "WPILib.h"
class CompassBot : public SimpleRobot {
	HiTechnicCompass compass; // Define compass object
public:
	float angle;
	CompassBot(void):
		compass(1) // Initialize to i2c port 1
		GetWatchdog().SetExpiration(0.1);
	void Autonomous(void) { }
	void OperatorControl(void) {
		while (IsOperatorControl()) {
			angle = compass.GetAngle(); // Get the angle (returns float)
			printf("Current Angle: %f", angle); // Print angle
START_ROBOT_CLASS(CompassBot);
Unread 30-01-2010, 18:16
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I second the HiTechnic compass. I found it to have a normal accuracy of +/-2-3 degrees, and a worst case accuracy of +/- 5 degrees. Your results may very, but I found the only issue to be the lag getting info from the sensor.
If you need quick response times you should look at using the included gyro. It is almost as simple to configure and use as the compass.
Eric Haskins KC9JVH
Unread 01-02-2010, 00:37
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
I will third the HiTechnic but might I sugest a gyro. The gyro only floats by a couple degrees throughout the match it you mount it flat and it isn't as sensative to interference.
Which operating system do you use/want to use? neutrino15 Programming 17 12-01-2008 00:05
Which gear pitch to use Someone Technical Discussion 11 02-11-2005 12:50
Which shaft encoder to use? Jeff Waegelin Electrical 22 18-06-2005 03:57
Which browser do you use? jonathan lall Website Design/Showcase 17 11-07-2004 17:20
Which motors should i use??? archiver 2001 2 23-06-2002 23:10
