Go to Post Each year that I've been on the team I've thought to myself, "Man we lost some great seniors this year," and each year younger students have stepped up on their own to fill those leadership positions. - BJC [more]
Unread 01-02-2010, 02:33
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
lift winch ideas anyone?
Hi,
I've recently just started designing our lifter. Unfortunately, I don't have permission to release our idea, but what I can say is that we are using a winch type mechanism.
I want to design a small winch capable of lifting just our robot (120lbs) using as many COTS products as possible. Have any of you thought about a design for such a winch.
We are thinking about using two counter-rotating drums that are driven off a single motor. The questions we have is what motor/gearbox to use.
Thanks for your input,
windell
Unread 01-02-2010, 02:37
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: lift winch ideas anyone?
Would your design be similar to any of these: http://www.chiefdelphi.com/forums/sh...ad.php?t=80152
What motors do you have left in the KoP after they drive base and kicker?
Thanks,
timytamy
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 01-02-2010, 03:25
Got a better idea for you, depending on your winch setup. 1 drum, 2 sections, running the outbound cord off one side and the inbound off the other one. I've been on a team that did 3 steel cables off one drum, powered by 2 Fisher-Price motors with KOP gearboxes, for lifting a robot.
Setup: the F-P motors are mounted as described in other threads. Each powered one end of the drum through an adapter. The drum itself was lathed into 3 sections--center was the "incoming" cable and the sides were both "outgoing" during a lift. The incoming cable and the outgoing cables were wound in opposite directions.
What I'd do these days, given that that adapter is no longer in the KOP: make an octagon for a FP-keyed shaft interface, and make something similar for a drum of the appropriate size. Or find a source for it.
Unread 01-02-2010, 04:27
FRC #2477
Thanks Eric and Timy! We have the FP motors, and the small motors left in the KOPs. We might consider ordering a few CIMs.
How does this idea sound? A CIM (or two CIMs) attached to a worm gear/ gear set that turns one drum. To turn the other drum, spur gears are between the two drums causing them to counter-rotate.
Can we use more than 4 CIMs? I forget what the rule is.
Thanks!
Unread 01-02-2010, 04:32
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
At this point in the season if you don't know it you should at least know where to look:
http://www.usfirst.org/uploadedFiles...Robot_RevF.pdf
Unread 01-02-2010, 06:16
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
<R52>
D. One, two, or three additional 2½” CIM motors (part #FR801-001 and/or M4-R0062-12) in
addition to those provided in the KOP. This means that up to five, and no more, 2½” CIM
motors can be used on the ROBOT.
Unread 01-02-2010, 06:42
FRC #2477
Thank you Jun! I think I was thinking about a rule from a previous season which allowed the use of only 4 CIMs. Its nice to know that we are allowed to use 5 instead of 4.
Unread 01-02-2010, 08:39
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
You should assume 150lb for the weight of the robot with bumpers and a batt.
Every day is a new adventure!!!
Unread 01-02-2010, 09:07
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Even if you plan on being light (90 lbs + 10 lbs battery + 20 lbs bumper =120 lbs), "the man" is right that you should assum 150 lbs. as your team may want to add future functionality (reset arm, more poerful kicker...) or may have trouble making it to the designed weight. By the rules though, you shouldn't excede 150 lbs and be competition legal, so that is a better assumption.
Unread 01-02-2010, 09:12
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Founder, 469 Mentor
FRC #0469
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
Some compact COT winches use planetary systems mounted inside the drum.
Could work to keep things small.
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 01-02-2010, 18:12
Dick Linn's Avatar
no team (Synergy)
You could use a differential windlass principle for a winch. It's easy to get a tremendous mechanical advantage if you don't mind using quite a bit of cord. Search on "differential windlass" or "Chinese windlass". Same principle is used in chain hoists (chain falls). It might eliminate all the heavy, expensive gearboxes.
Oh, perhaps someone can figure out how to use this 33:1 torque multiplier in a winch application:
http://www.harborfreight.com/cpi/cta...emnumber=93645
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-02-2010, 23:28
DonRotolo's Avatar
Back to humble
FRC #0832
Also consider that you don't want the lift to take 15 seconds - design for much faster than that. How many times we've seen a nice lifting mechanism, engaged and lifting with 15 seconds to go....and they don't make it, because their design sacrificed speed for power.
Unread 02-02-2010, 00:39
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
This would do fine, in fact I was playing with the one we bought for our lift system today. Small, light, cute.
http://www.grainger.com/Grainger/items/6Z001?Pid=search
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 03-02-2010, 20:19
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
we use pneumatics to lift up the hook, and a winch to pull us up, somehow driven by a CIM
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 04-02-2010, 08:41
terryo terryo is offline
AKA: Terry O'Brien
FRC #1784 (Litchbots)
terryo is an unknown quantity at this point
We're using a similar winch driven by a CIM and toughbox using sprockets and chain. A bifold arm driven by 2 Denso's extends the hook, a pair of cylinders lifts up the front wheels, we drive up against the bar and lower the cylinders to attach the hook, then retract the arm and start winching. 2 " dia drum on the 3.1:1 winch gives us over 400# lifting force and gets us above the platform in <10 seconds. (in case an alliance member wants to come along for the ride)
Want to buy a scissor lift for our cart, any ideas? Team1824 General Forum 1 02-03-2009 15:47
Scissort Lift vs. Crane vs. 4-Bar Lift vs. Gas Springs AdamC Technical Discussion 31 20-01-2008 18:49
Cable Ideas?? Anyone? Zak698 General Forum 2 14-08-2006 20:03
Winch edomus General Forum 43 21-02-2004 02:30
