Go to Post The people that have posted in this thread are intelligent and I know that when they talk, I need to listen. - ATannahill [more]
Unread 12-01-2010, 08:20
MachineSMMC MachineSMMC is offline
FRC #3026
MachineSMMC is an unknown quantity at this point
Tank Treads
I am looking for some opinions on the rule <R08>
<R08> ROBOT wheels, tracks, and other parts intended to provide traction on the FIELD may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not allowed.
So, is it legal to use a timing belt with the teeth gripping the carpet? I think this is legal because the teeth are not attachments.
Thoughts?
Chris Tellers
Team #3026
Orange Crush
Unread 12-01-2010, 08:26
karatekid's Avatar
karatekid karatekid is offline
AKA: Cole
karatekid has a spectacular aura aboutkaratekid has a spectacular aura aboutkaratekid has a spectacular aura about
Re: Tank Treads
I think it depends on how sharp your teeth are and what they are made of. Rubber "teeth", like on tank treads, should be fine. However, if you were to put in sharpened studs, they would consider that illegal. Hope this helps.
YOU JUST LOST THE GAME!
Unread 01-02-2010, 09:26
devodl devodl is offline
AKA: Steve Deal
FRC #0578 (R3 - Red Raider Robotics)
devodl is just really nicedevodl is just really nicedevodl is just really nicedevodl is just really nicedevodl is just really nice
Re: Tank Treads
"I'm a bit fuzzy on the whole good/bad thing here. "
In Section 8.3.1 under R08 it states:
ROBOT wheels, tracks, and other parts intended to provide traction on the carpet may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not allowed.
I believe the whole intent of R08 is to prevent damage to the field which is good but the Rule seems ambiguous and general and as a result overly restrictive when it comes to materials and design of a track.
Specifically my questions are:
  1. Can you use a metal track that has "treads" (not "studs" or cleats")?
  2. What is "hard" plastic? Is "hard" quantified using the Durometer or Rockwell scales?
  3. What is meant by "other attachments"?
A conservative interpretation could be that you couldn't use metal or "hard" plastic chain but a "hard" rubber chain (or timing belt) is okay.
More importantly if you "fabricate" a track using commercial components then what qualifies as an "attachment"?
Unread 01-02-2010, 10:06
ewoodring ewoodring is offline
AKA: Eric
FRC #2474 (Excel)
ewoodring is an unknown quantity at this point
Re: Tank Treads
Like what devodl said, the GDC is trying to keep the field from being torn up. What you can do, is test your treads on a piece of carpet. If they tear up your carpet, they probably aren't allowed.
Unread 01-02-2010, 10:25
AKA: Steve Deal
Re: Tank Treads
Agreed, but I am trying to understand what IS allowed.
If I make a track with "hard" plastic "cleats" that are "attached" to a track then based on R08 they aren't allowed for 3 reasons.
Even if the tracks don't damage the field whatsoever.
Heck, wheels can burn a hole in the carpet more easily than a track but I don't see ambigous, generalized restrictions on wheels in the rules.
Unread 01-02-2010, 10:43
Re: Tank Treads
Originally Posted by devodl View Post
[*]Can you use a metal track that has "treads" (not "studs" or cleats")?[*]What is "hard" plastic? Is "hard" quantified using the Durometer or Rockwell scales?[*]What is meant by "other attachments"?
All of the answers below are general responses. More specific responses would require actual part numbers or pictures.
In general, metal tracks that have rubber treads might be allowed if the metal has no possibility of ever contacting the carpet or exuding lubricant that would stain or otherwise damage the carpet. This might also include wire reinforced tracks where the wires either begin exposed or through wear break out of the belt and contact the floor. Inspectors are not the only officials that have input on this.
Hard plastic is just that. Something that when you feel it you think "That's really hard, I bet it is going to rip some carpet!" This comes from teams adding plastic studs to track or wheels to give extra grip in past competitions.
Other attachments is anything that gives extra grip to the original material, be it aluminum cleats, nylon screws, abrasives, sand, file cards, wire brushes, etc.
Unread 01-02-2010, 10:49
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Tank Treads
Generally, the rule against "hard" items against the floor is to prevent a popular practice "back in the day" of screwing drywall screws into skyway wheels to get cheap "cleats" that increased traction. (The carpet really didn't like that). Heck, I remember teams with full metal tracks back before this rule existed.
It came about after 2k2 with the "file card" anchor robots (plus a plethora of other carpet threatening devices). Anyone that took part in that year's competitions knows what the carpets looked like afterwards.
I think it comes down to:
Are there "hard" parts of the tread that are in contact with the carpet? ("hard" meaning anything but rubber or smooth slider-type plastic)
If so, I'd expect to have it thoroughly examined by inspectors on Thrusday.
Unread 01-02-2010, 11:24
AKA: Steve Deal
Re: Tank Treads
I understand the intent of the rule (don't damage the field) but as an engineer I have difficulty accepting the ambiguous definitions. If two robots get in a shoving match they could damage the rug but their design was approved if they used rubber wheels.
Sounds like the only answer for tracks is: It depends on the inspector.
- "cleat" vs tread
- "hard" vs soft
- "attached" vs fastened, bonded, affixed
I know time is short but is there a process to get an official ruling prior to the competition?
Unread 01-02-2010, 11:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Tank Treads
I have not seen carpet damaged by rubber treaded wheels, even when robots get in heavy pushing matches. Of course I have not inspected all fields after all matches, but it's generally not a problem.
The rule is kind of ambiguous about what you can put on the robot, but it's intent should be obvious--if whatever you put on the carpet can damage the carpet, it's not allowed.
Unread 01-02-2010, 11:40
MrForbes's Avatar
AKA: Jim
Re: Tank Treads
Ask on the Q&A.
http://forums.usfirst.org/forumdisplay.php?f=23
your team representative who has access to FIRST TIMS will need to get the password for your team to do this.
Suggest you read the questions and answers to get a feel for how it works, before you ask your question.
Unread 01-02-2010, 12:00
AKA: Steve Deal
Re: Tank Treads
Thank you all for your responses, advice and opinions. I really appreciate it.
Unread 01-02-2010, 12:13
Matt C's Avatar
FRC #1468 (J-Birds)
Re: Tank Treads
For reference, stuff like THIS would no longer be allowed.
You could post pictures of what you intend to use.
Unread 01-02-2010, 14:23
Re: Tank Treads
Just so everyone knows...
There will be carpet damage this year as robots trying to drive over the hump get hung up and one wheel spins on the floor as a team tries to get back in the game. The friction will cause some damage. The object is to minimize this for the enjoyment of all.
Unread 01-02-2010, 15:35
copperhead47's Avatar
copperhead47 copperhead47 is offline
AKA: Grant "gunner" T.
FRC #1647 (Lenape Regional Iron Devils)
Team Role: Electrical
copperhead47 is an unknown quantity at this point
Send a message via AIM to copperhead47
Re: Tank Treads
i feel like "hard" plastic is something that has a tendency to shatter or fracture under pressure rather than bend
Unread 02-02-2010, 15:38
AKA: Steve Deal
Re: Tank Treads
Is PVC "hard"?
Trick question: Which plastic on this chart is "hard"?
http://www.ides.com/property_descrip...sion-chart.asp
Of course it's not just the hardness of the plastic but the shape of the tread/cleat as well. Pointy "soft" plastic could cause more damage to the carpet than rounded "hard" plastic.
I can get around the "hard" plastic restriction but I'm stumped by the <R08> restriction on "other attachments".
Question
If I fabricate a track (<R08>) by fastening rubber treads to a chain, are the tracks ruled illegal (i.e. violate <R08>) because they have "other attachments"?
Tank Treads Andrew.Jensen General Forum 37 14-01-2010 10:53
Tank Treads??? SLA Kit & Additional Hardware 2 16-01-2007 20:53
Tank treads teh_masterer Technical Discussion 3 11-01-2006 18:11
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Tank Treads dddriveman Kit & Additional Hardware 27 06-05-2004 18:16
