Go to Post We never play to lose, or even go easy. We play our best every match. - Paul H [more]
Unread 01-02-2010, 02:24
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
increasing flow rate to pnuematic cylinder
Hi, you guys probably already know about this, but we're pretty disappointed at the velocity of the pnuematic cylinders. I've heard that this is partially due to the diameter of the tubes.
Does anyone have any suggestions as to how to increase the flow rate to the cylinders?
Are we allowed to use tubing with a larger ID?
I've also read that some teams are using T fittings at the inlet of their cylinders. Is this legal?
Much appreciated!
Windell
Unread 01-02-2010, 03:29
laxcompute laxcompute is offline
FRC #3245 (Waterford Ravens)
laxcompute is on a distinguished road
Re: increasing flow rate to pnuematic cylinder
We're a rookie team, and in the process of designing our pneumatic system. So I've ran across some of this stuff.
1. Flow rate to the cylinders is limited both by the diameter of the provided tubing (either .106" or .160", I can't remember which at the moment) and the maximum legal cV on the valves used, which is 0.32 (unitless). Basically, that means that air moves slowly. You could use cylinders with the smallest diameter, but that of course limits your force.
2. No. The provided tubing is already the maximum dimensions.
3. Yes, but from what I've read, you cancel out anything you gain by having theoretically increased flow, because of the currents when the two channels of air come back together.
Unread 01-02-2010, 09:26
Much appreciated!
Windell
consider other design options:
http://www.chiefdelphi.com/forums/showpost.php?p=910176
some answers to pneumatics "legality" questions:
http://forums.usfirst.org/showthread.php?t=13976
http://forums.usfirst.org/showthread.php?t=14227
http://forums.usfirst.org/showthread.php?t=14218
http://forums.usfirst.org/showthread.php?t=14196
http://forums.usfirst.org/showthread.php?t=13957
Unread 01-02-2010, 11:28
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Read through the First Q&A forum. Several methods that have recieved GDC approval there.
http://forums.usfirst.org/forumdisplay.php?f=1398
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 01-02-2010, 14:01
dtengineering's Avatar
AKA: Jason Brett
Here's my thoughts on the situation:
http://www.chiefdelphi.com/forums/sh...839#post907839
Unread 01-02-2010, 14:39
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Cv is not unitless. The Cv of a valve is the "flow rate in US Gallons per minute [gpm] of water at a temperature of 60 Fahrenheit with a pressure drop across the valve of 1 psi."
Source: http://www.valvias.com/flow-coefficient.php
Also see:
http://en.wikipedia.org/wiki/Flow_coefficient
Unread 01-02-2010, 16:20
Also see:
Great teaching stuff Matt. Thanks. I was looking for some nice graphs to show my team of airflow (either mass airflow or scfm) versus pressure drop for various Cv values, but was unsuccessful.
Just wondering if maybe you had found some and could share the links.
Unread 02-02-2010, 00:54
Cool. I stand corrected. But hey, a week ago I didn't even know what cV meant at all, so I can live with that =p
Nice to learn (yet something else) new.
Friction-increasing substances nayer247 Technical Discussion 15 29-01-2009 12:10
Increasing available program memory DanDon Programming 21 30-05-2005 17:00
Flow Switch question? Inert Entry Pneumatics 1 28-02-2005 16:22
White Paper Discuss: Increasing A/D Resolution Using Noise CD47-Bot Extra Discussion 7 12-10-2004 09:26
Flow rate / remaining pressure swabbie58 Pneumatics 5 11-02-2004 12:57
