Go to Post "at some point in the next six weeks you are going to start feeling like you are involved in a robot building contest. Then you are in serious trouble" -Dean Kamen - KenWittlief [more]
Unread 01-02-2010, 09:55
thatoneguy23's Avatar
thatoneguy23 thatoneguy23 is offline
Fiding everything we need to know.
FRC #2389 (Oklahoma STORM)
Team Role: Scout
thatoneguy23 is on a distinguished road
Corraling the ball
Our frame designers are trying to give us the to center the ball if it hits the front edges of our frame. I'm just wanting to know how you guys are planning on doing it, and if you could give us some hints.
Thanks
I think, therefore I am lost....- Me
"The difference between me and the rest of the world is sanity. They have it, I don't"
Unread 01-02-2010, 10:52
Techgirl675's Avatar
Techgirl675 Techgirl675 is offline
FRC #0675
Techgirl675 will become famous soon enough
Send a message via AIM to Techgirl675
Question Re: Corraling the ball
Care to rephrase the question?
Unread 01-02-2010, 10:55
Search the forums for "ball magnet".
Unread 01-02-2010, 10:59
Team Role: Scout
sorry for the inclarity, and thanks for the search topic
I was just trying to figure out about what some other teams were going to do to keep the ball centered when going around the arena.
Unread 01-02-2010, 11:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We are planning on having a wide kicker, so the ball does not need to be centered.
One of these days we'll get our robot to actually kick a ball...we hope....
Unread 01-02-2010, 11:25
Team Role: Scout
I know how you feel about the maybe soon we will be able to kick a ball.
Back on topic, our team is planning to have a cut out in the frame (less than 3 inches of course) that will put the ball centered.
Unread 01-02-2010, 11:26
MrForbes's Avatar
AKA: Jim
We figured that having a wider area for the ball to go into, would make it easier to get a hold of the ball. Making the robot so that it can handle the game pieces easily (without having to aim carefully) really helps your scoring ability.
Unread 01-02-2010, 12:51
jhaugen jhaugen is offline
J. Haugen
FRC #0842 (Carl Hayden Falcons)
jhaugen is an unknown quantity at this point
Our 2 side kickers go the complete length of the frame and our front and rear kickers narrowly miss the side bars. We have successfully kicked the ball with all four kickers.
Unread 01-02-2010, 15:51
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Now we have to figure out how to hold on to the ball
Faridodin "Fredi" Lajvardi KD7WKD
Unread 02-02-2010, 22:54
TXT TXT is offline
FRC #2550
TXT is an unknown quantity at this point
Post Re: Corraling the ball
According to Section Seven,
"POSSESSION: Controlling the position and movement of a BALL. A BALL shall be considered in POSSESSION if, as the ROBOT moves or changes orientation (e.g. backs up or spins in place), the BALL remains in approximately the same position relative to the ROBOT."
Therefore, any method of centering the ball must not lock it into position for any portion of time. (Or a penalty will be "awarded" to the offending team- <G43>) In real soccer, players use the sides of their feet when kicking for greater control and precision.
Solution- use a wide kicker, don't corral the ball into a position that it can't get out of during movement.
Unread 02-02-2010, 22:58
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
<G43> does not prohibit POSSESSION, it limits POSSESSION to one ball at a time.
Unread 02-02-2010, 23:04
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
I have noticed that sooooooo many people are having the same misinterpretation. I know that our team did to begin with, and I wish that there was some way to get it through to each and every team. You can posses one ball. I will say that again, YOU MAY POSSES ONE BALL!!! Hopefully that will catch peoples attention!
Unread 03-02-2010, 10:40
Team Role: Scout
what will catch peoples attention?
jk.. thanks everyone
What do you think is the best way to pick up the ball? Jamin008 Technical Discussion 5 14-01-2008 20:47
Carrying the ball under the overpass but across the finish line BaldGuy Rules/Strategy 13 09-01-2008 14:53
Question: What If The Ball Goes out of the Arena?... DanTheRobotMan Rules/Strategy 13 12-01-2006 18:20
2X Ball Into the Ball Release MikeDubreuil Rules/Strategy 23 28-03-2004 19:31
