Go to Post There are "Problems", and then there are "Solutions". Understand the Problem, and keep your mind open to alternative solutions. Don't get married to a Solution. - rich2202 [more]
Unread 01-02-2010, 01:31
AdamHeard's Avatar
Lead Mentor
Mabuchi Motor replacement
I've been trying to find motors with similar specs to the two mabuchis in the kit to use on our practice bot (to not waste valuable spares...).
Banebots doesn't stock anything similar, nor does robotmarketplace, so that rules out the places I know of.
Unread 01-02-2010, 01:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Mabuchi Motor replacement
I googled the part numbers and didn't find anything.
Unread 01-02-2010, 01:59
Chris is me's Avatar
AKA: Pinecone
Would pretty much anything in the RS-555 line work? It's just practice. I don't know enough about the motors to know how different they are, but if it's just to get a robot running similarly...
Unread 01-02-2010, 06:53
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
many cordless drills contain similar motors. If you have some that you're not afraid to disassemble you might want to try that.
Unread 01-02-2010, 09:26
MrForbes's Avatar
AKA: Jim
The RS-555 "standard" seems to refer to the mounting specs and overall physical size of the motor. There are many, many different electrical/power specs used to make motors in this series. So no, I doubt you'll even be able to get it to run similarly by using any old RS-555 motor.
Unread 01-02-2010, 10:16
AdamHeard's Avatar
Lead Mentor
I've googled some in addition, I have yet to find any that are even close in free speed.
Unread 01-02-2010, 10:51
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Not sure of the specs, but here's something potentially similar. http://www.allelectronics.com/make-a...C-MOTOR/1.html
Unread 01-02-2010, 12:54
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I did a bit of looking out of curiosity and I was able to find this:
http://www.yeno-electronics.com/prod...?ProductID=728
They're in China though, so I doubt you'd be able to get it in any short amount of time and they probably don't want to deal with single orders either...
Has anyone tried contacting Mabuchi Directly?
-Dustin Benedict
Unread 01-02-2010, 13:52
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
I didn't really have time to compare the specs, but Banebots has this and many other brushed DC motors
http://banebots.com/pc/MOTOR-BRUSH/M5-RS555-12
Mabuchi Motor Supplier RMS11 Motors 10 28-01-2010 23:22
Mabuchi Motor: Rs-385 R.C. Motors 9 27-12-2009 09:25
Mabuchi Motor Curves ,4lex S. Motors 0 10-01-2008 15:51
Mabuchi Motor Paul Copioli Motors 1 08-01-2002 10:26
