Go to Post We learned that no matter the outcome when you don't give up you will always win. - Koko Ed [more]
Unread 30-01-2010, 20:44
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
Is there a Way To refrence a true false statement
yeah is there a way?
Unread 30-01-2010, 20:52
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Is there a Way To refrence a true false statement
Do you mean the output of a T/F statement? That is, whether it ended up T or F? Or something else?
Unread 30-01-2010, 20:57
i didnt explain it well
since we have the basic.vi and teleop.vi
i want to route the motor invert from basic.vi into the teleop to use a case structure to invert the motor at a push of a button
Unread 30-01-2010, 21:08
I don't know of any "Basic.vi," but yes you can pass variables between vi's.
There are several different ways to do so.
Tell us a little bit about basic.vi first, like where is it and what are you doing in it.
Unread 30-01-2010, 21:09
i ment begin sorry about that;
Unread 30-01-2010, 21:30
You know, I know another team that wants to do something like that too.
Planning to Close and Reopen your 2 or 4 motor drive?
You can simplify that particular problem, since Begin.vi is only ever called one time and the starting values of Invert are hardcoded. You already know in Teleop.vi what values would be passed in. It's much easier to just keep that information local to teleop.vi.
You can pass the value of your Invert to teleop.vi with a global variable if you so choose. Your team probably used global variables last year.
Unread 30-01-2010, 21:38
we didnt use global variables last year, i dont understand how to use them
Unread 30-01-2010, 22:29
This is in LabVIEW Help, but it's a bit hard to find.
  • Open the Begin.vi block diagram
  • Right-click for the Functions palette and go to Programming -> Structures and you'll see "GLOB" (for global variable) down at the bottom. Add that to your Begin.vi
  • Double click on the Global and you'll get a blank front panel.
  • Right-click on the Global front panel and add two boolean controls (doesn't matter which ones) to the global front panel. Rename them "Left Motor Invert" and "Right Motor Invert" or whatever you want to call them.
  • Save and close that global front panel. You'll be asked to give it a name, pick whatever you like, but be creative. I hate boring names.
  • Back in the Begin.vi block diagram right-click on that global you added before (it'll look like a globe), and choose Select Item -> Left Motor Invert.
  • Now copy and paste that global and right-click Select Item -> Right Motor Invert on that new one.
  • Wire both of those to you-know-where. Those values you wanted to send to Teleop.vi.
  • Save it and you now have global variables you can use anywhere.
Meanwhile, over in teleop.vi...
  • Highlight the two global variables you just made in Begin.vi and copy them.
  • Open the Teleop.vi block diagram and paste the global variables in.
  • Right-click on each of them and select "Change To Read" and now you can drag a wire from it to your case statement.
  • You can make more copies wherever you want to write back to them.
Unread 30-01-2010, 22:32
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
A little off topic, but it reminded me:
Do you HAVE to close whatever it is in the end vi? I forgot to and didn't notice a difference.
Unread 30-01-2010, 22:34
That is bizarrely off-topic...
Did you just pick the uppermost thread on the portal to ask your question?
If you fail to close things they will come back to haunt you after the season...
Unread 30-01-2010, 23:56
It might be easier for you to add a case block to either multiply your motor control value by -1 or leave it alone, based on your pushbutton.
Unread 31-01-2010, 11:05
thanks alot imma try it when i reach today; i was searching in the help but it only gave me a small description how to do it
Unread 01-02-2010, 10:29
Danielle Danielle is offline
AKA: Jake
FRC #2164 (The Corps)
Danielle is an unknown quantity at this point
You could use a joystick button and wire it directly to the open motor invert terminal.
1) Unbundle the buttons (brown 'out' terminal) on the JoystickGet.vi [this can be done by right clicking on the terminal, most things in LabView can, I've found new love for my right mouse button ]
2) Wire the desired button to the invert terminal on the OpenMotor.vi (2 motors or 4, it doesn't matter)
Unread 01-02-2010, 10:30
AKA: Jake
BTW; I'm picturing this code in the Begin.vi
Unread 01-02-2010, 10:56
That solution won't work in this case.
The Begin.vi happens only once when the robot is first turned on, and they want to change the value on-the-fly during the match.
Is there a way to display Cmaer Live footage? Tottanka FRC Control System 0 12-12-2008 11:21
Is it true that there is not going to be UC Davis Sacramento Region next year? jimmythetulip22 General Forum 14 03-03-2008 23:54
Is there a way to read your Team Colour during autonomous mode? Firestorm Programming 2 19-02-2005 18:57
Way back there. Size of Nationals, and a solution archiver 2001 23 24-06-2002 03:28
is it true? are there pics of TEAM 1?? archiver 2000 3 23-06-2002 22:19
