Go to Post "FIRST" is not a verb (yet - give us time, and we will see what happens). - dlavery [more]
Unread 16-01-2010, 16:21
Us3rNam3's Avatar
Us3rNam3 Us3rNam3 is offline
Is LabVIEW code lighter than C++?
AKA: Tristan
FRC #1625 (Winnovation)
Us3rNam3 is an unknown quantity at this point
Question using CAN with the 2010 control system
Does anyone have any tips or know to program using CAN using the Andy Mark adapter? Any info on how to use CAN would be greatly appreciated. Diagrams/pics of code would especially helpful.
Thank you
DFTBA. NERDFIGHTERIA FOREVER!
J'adore les robo.
Unread 16-01-2010, 23:14
Re: using CAN with the 2010 control system
You can find documentation and example code here.
(The 2CAN is made by Cross The Road Electronics. AndyMark is merely acting as a distributor.)
Unread 17-01-2010, 13:59
Us3rNam3's Avatar
AKA: Tristan
thank you...but unfortunately i forgot to include that i need it for labVIEW not c++
J'adore les robo.
Unread 17-01-2010, 14:53
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Send an email to Omar Zrien (ozrien@gmail.com).
Originally Posted by Omar Zrien
The cRIO driver/interface will allow you to transmit and receive "CAN Frames", whereby a CAN frame will be defined as a structure with arbid, data bytes, len, and also status bits for selecting extended ids, remote frames, and also possibly error information (Transmit Error Count, Receive Error Count).
I suppose it is possible that they don't have a license to LabVIEW, and thus can't do the LabVIEW portion themselves. In looking at it, it's a UDP datagram of a struct[ message, arbitration ID].
If I had experience with UDP, I'd do it myself.
-- Marshal Horn
Unread 17-01-2010, 21:37
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The LabVIEW API (as well as C++ and Java) for using CAN is here: http://firstforge.wpi.edu/sf/projects/canjaguar
The C++ API that CTRE has posted will not work with FRC 2010, based on the rules requirement of using the FIRST specific Jaguar firmware.
Unread 17-01-2010, 21:50
BTW, the plugin for the 2CAN has not been released yet. When it is, you will be able to find it at FIRST Forge.
Another way to connect to CAN is to use the new Black Jaguar as a serial to CAN bridge. You just make the cable according the the getting started guide from TI and plug it straight into the RS232 serial port on the cRIO. This way you don't need to buy a separate bridge device and can simply use one of your motor controllers. The driver plugin for using the Black Jaguar as a Serial to CAN bridge is posted on FIRST Forge.
If you are going to use a lot of motors in open loop mode, you may need the additional bandwidth of Ethernet.
Unread 21-01-2010, 22:42
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
If anyone has difficulty navigating the FIRST Forge site looking for the LabVIEW code to use with Jaguar / CAN, here is a deep link to the zip file (at least where it is today):
http://firstforge.wpi.edu/sf/frs/do/...ar_for_labview
Unread 30-01-2010, 18:06
Andy Bradley Andy Bradley is offline
FRC #0233
Andy Bradley is an unknown quantity at this point
Thanks very much. Do you know in which directory the extracted files should be placed so that LabView can see them?
Unread 30-01-2010, 23:26
We put them in
C:\Program Files\National Instruments\LabVIEW 8.6\user.lib\CANJaguar for LabVIEW
They will then show up in your User Libraries palette in LabVIEW.
Unread 01-02-2010, 10:29
imcmahon01 imcmahon01 is offline
FRC #1143
imcmahon01 has a spectacular aura aboutimcmahon01 has a spectacular aura aboutimcmahon01 has a spectacular aura about
I have a similar question to Andy's. Our team is using the netbeans ide; how is the CANJaguar for Java folder added as a library to allow the use of edu.wpi.first.addons.CANJaguar?
Unread 01-02-2010, 10:57
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Our team has looked at the Java CANJaguar release, and at the moment only voltage setting is supported - none of the closed-loop methods are implemented yet.
I'm not sure if the primary developers are planning to release another update before the end of build, but we plan to try to implement some of the functionality we need ourselves. If we have success we will make our efforts available to the community.
In the meantime, the bdc-comm utility does allow some experimentation with closed loop control, but obviously not under actual robot conditions.
Unread 01-02-2010, 12:59
This is the first I've heard of a team wanting to use CANJaguar with Java. I've not ported the C++ class's closed loop methods to Java yet because I had not heard any demand. I'll either do it or find someone else to do it before the end of build.
-Joe
Unread 01-02-2010, 13:04
MikeE's Avatar
no team (Volunteer)
Thanks for the quick reply Joe. The team decided to program in Java this year since it is the language taught at the High School, and we only started seriously investigating CANJaguar support this past weekend.
I also realize this is the wrong sub-forum for Java discussion, so apologies for hijacking a Labview thread.
Tips for C++ programming the 2010 control system woodk C/C++ 12 23-01-2010 21:38
2010 Control System Manual screamingeagle FRC Control System 9 11-01-2010 14:01
Unclaassified: Information about the 2010 control system Nadav Zingerman General Forum 35 24-11-2009 19:17
Do we have to ship the control system along with the robot on Tuesday? tennisbeast29 Rules/Strategy 3 14-02-2009 13:39
