Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Unread 01-02-2010, 12:33
ThisAintJeff's Avatar
ThisAintJeff ThisAintJeff is offline
FRC #1591 (Greece Gladiators)
ThisAintJeff is an unknown quantity at this point
Send a message via AIM to ThisAintJeff
cRIO wont run software
alright, so this year our team had to use the cRIO from last years robot. we've written a teleop code (in labview), and seems to have no errors. however, when i go to deploy the code to the cRIO, it says its expecting a nother version of data or something. im guessing it has to do with updating it, but i cant find any tools or patches.
Unread 01-02-2010, 13:16
Re: cRIO wont run software
Update your LabVIEW installation, then run the FRC cRIO Imaging Tool to load the v19 image. You will find a pointer to the mandatory update here:
http://www.usfirst.org/frccontrolsystem
While you're at it, make sure your Driver Station is updated as well. If your Dashboard doesn't show a directional compass indicator, you'll have to run the updater twice, first uninstalling then reinstalling the files.
Unread 01-02-2010, 14:58
i have run the installer before, it shows that i have the image of FRC_2010_v5.zip
is there anyplace i can just load v19 from?
Unread 01-02-2010, 15:57
If you have v5, the update was not applied successfully.
Follow the links to the LabVIEW update and get a fresh copy of it. Run it to update your development system. Then you'll have the v19 image.
Unread 02-02-2010, 15:47
thank you yet again alan!
Help computer wont recognize cRio bio hazard NI LabVIEW 3 14-02-2009 19:24
DS tty serial and crio run speed Mr-Shutter FRC Control System 5 21-01-2009 12:39
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
cRIO wont save program Arcre NI LabVIEW 5 07-01-2009 11:45
Will the parallax stamp software run win win2k? Joe Ross Programming 5 25-08-2001 13:38
