Go to Post Any adult can open a door. Some can give direction. A few can give leadership. These are the true mentors. This is where true success comes from. - sanddrag [more]
Unread 01-02-2010, 14:15
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Bungy and Surgical tubing
If you are worried about the piston breaking itself because it hits the end stop to hard to many times then Bimba does sell pistons with adjustable air cushions at one or both ends.
Bruce
Surgical Tubing spring rate? Tom Line Technical Discussion 9 30-01-2011 14:33
Surgical Tubing? rogue5n1per Kit & Additional Hardware 1 19-01-2010 22:05
How do you connect surgical tubing? Marlfox Technical Discussion 7 17-01-2009 15:19
[OCCRA]: Surgical Tubing iwanttodunk OCCRA Q&A 1 07-10-2008 06:28
Surgical Tubing punky2k1 Off-Season Events 1 24-10-2001 20:58
