Go to Post They just kind of sit there chilling, like "Hey I'm a trailer, where's my robot?" - artdutra04 [more]
Unread 01-02-2010, 14:39
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: increasing flow rate to pnuematic cylinder
Originally Posted by laxcompute View Post
1. Flow rate to the cylinders is limited both by the diameter of the provided tubing (either .106" or .160", I can't remember which at the moment) and the maximum legal cV on the valves used, which is 0.32 (unitless). Basically, that means that air moves slowly. You could use cylinders with the smallest diameter, but that of course limits your force.
Cv is not unitless. The Cv of a valve is the "flow rate in US Gallons per minute [gpm] of water at a temperature of 60 Fahrenheit with a pressure drop across the valve of 1 psi."
Source: http://www.valvias.com/flow-coefficient.php
Also see:
http://en.wikipedia.org/wiki/Flow_coefficient
Friction-increasing substances nayer247 Technical Discussion 15 29-01-2009 12:10
Increasing available program memory DanDon Programming 21 30-05-2005 17:00
Flow Switch question? Inert Entry Pneumatics 1 28-02-2005 16:22
White Paper Discuss: Increasing A/D Resolution Using Noise CD47-Bot Extra Discussion 7 12-10-2004 09:26
Flow rate / remaining pressure swabbie58 Pneumatics 5 11-02-2004 12:57
