Go to Post I think there are a ton of teams that would kill for one let alone three engineering mentors (especially one with the knowledge and experience that Rich Olivera has). - XaulZan11 [more]
Unread 30-01-2010, 15:10
Steve Warner Steve Warner is offline
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
Chattering Relay and RSL flashing too fast
I think this post is similar to others regarding the traffic between the DS and the cRIO. We are using C++ with the IterativeRobot class and added a Relay to the code. When in teleop mode, the relay led on the DSC would flicker, the spike would chatter and the RSL led would flash way too fast. After trying everything we could think of we rebooted the DS into developer mode and started the dashboard. The problem was gone when on the Operation tab but still there on the Diagnostics tab. Has anyone else seen this problem and does anyone know how to eliminated it on all tabs? Also, as many others have said, the camera lag time is much, much shorter in developer mode.
Unread 31-01-2010, 21:13
Re: Chattering Relay and RSL flashing too fast
The diagnostics tab pings the network elements, so naturally it has more overhead than the others. Also, the DS has quite a bit more overhead when disabled, and even more when the stop button has not been plugged in and isn't bypassed.
Greg McKaskle
Unread 01-02-2010, 14:57
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
FRC #1259 (Paradigm Shift)
Team Role: Electrical
MPG is an unknown quantity at this point
We are having the same problems as you with the relays and the signal light but we are programming in JAVA. We have tried switching out the DSC, swapping the module in slot four of the crio, moving that module to slot six, and even trying a different crio because we could not find anything wrong in the code. We did notice that if we took the camara tracking code out of our main code so that we would only have the relays running it helpped but they still flickered. If anyone knows how to fix this that would be much appreciated. Thank You
Team Robot Names
2010 = Oswald
2009 = Black Magic
2008 = Barnaby Rover
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Unread 19-02-2011, 21:08
hcps-ruwedt hcps-ruwedt is offline
FRC #0540
hcps-ruwedt is an unknown quantity at this point
We are using Labview, but we have been having the same problem. We have a compressor and a fan, but they have been working. Our lift mechanisms have not been working, and have been chattering and flickering. When we swap the pwm while it is running so that the pwm from the compressor is plugged into the lift relay, it works, but not when the code thinks it is a relay. We have been occasionaly having some improvements, but not complete success.
Unread 20-02-2011, 12:45
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
I'm no programmer, or electrical guy. But last year we did have some electrical problems that seemed to react like you're problems. I believe one problem was shorting on the digital sidecar. The other was a small short in the wiring for the camera.
I hope this helps or at least gives you somthing else to look for when debugging!
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
AnalogModule->GetAverageValue() gives wrong results if polled too fast davidc10 C/C++ 12 09-03-2009 03:01
pic: What Happens When You Go Too Fast... Ryan Dognaux Extra Discussion 16 31-03-2008 23:15
pic: Our machine is too fast... Arkorobotics Extra Discussion 22 25-01-2006 23:54
pic: Is this too fast??? sgsdragons Robot Showcase 3 15-02-2005 19:34
