Go to Post Safety glasses may be a nice forehead protector, but thats not what they are made for. - Quatitos [more]
  #76   Spotlight this post!
Unread 24-01-2010, 17:08
Aren_Hill's Avatar
Build Nifty Things
Re: Robot Lifting
they were oriented vertically for the majority of the match, then dropped down at the end.
A guy who likes robots.
  #77   Spotlight this post!
Unread 24-01-2010, 17:13
Chris is me's Avatar
AKA: Pinecone
Re: Robot Lifting
Some tips if you do try wings I learned from extremely simple and not very good prototypes:
1. With a robot roughly max width, you're just short of the max horizontal width on each side of the robot to fit in the 84 inch cylinder. So your forks would probably look like this:
2. Strong materials and fixed joints are key to cutting weight down. Once the forks are to the sides of your robot, an in bumper way to "lock" them helps, or a way to raise them ~5 degrees then lock to help ensure sliding doesn't happen. You can make the forks fall by gravity with a servo and "snap in" to place if you want.
3. Make sure your hanging mechanism works even if you only have one robot on one side. There are ways to do this.
  #78   Spotlight this post!
Unread 27-01-2010, 18:13
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
Re: Robot Lifting
what do people think about carabiners? well big ones! and what are peoples ideas for not getting stuck under the tunnel while trying to raise your robot up?
  #79   Spotlight this post!
Unread 28-01-2010, 07:03
MikePres's Avatar
MikePres MikePres is offline
A Dreamer
AKA: Michael Presman
FRC #3088 (Kill-O-Bites)
MikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud of
Send a message via ICQ to MikePres Send a message via MSN to MikePres
Re: Robot Lifting
Carabiners can be useful if your robot can apply enough force to make it stick there (for the spring gate to open, i mean).
If you don't wanna get stuck under the tunnel you can do it strategically by lifting the back of your robot before your front or mechanically by keeping your front bot in a curved shape or a straight one, without bumps to get stuck under there. Yes, i know, "what about the bumpers?!"... make some mechanism that will fall over your bumper to give your bot's front curved or higher than the tunnel.
for example:
###>DEVICE ########
BBBBBBBBBBBBBBBBBBBBBB
BBBBB>BUMPER BBBBBBBBB
Consider this with your peers and Mentors... Good luck
2010 Captain of...
Kill-O-Bites (#3088) - Crazy Enough to Work!
2009 Israel Regional Rookie Inspiration Award! =D
2010 Israel Regional Semi-Finalists and Coopertition Award! ^^
the first team ever to lose due to a coin-toss in the semis ^^"
Visit us: | our site (explorer only) | Blogger | twitter | YouTube | Facebook| FIRSTwiki | kob3088@gmail.com |
  #80   Spotlight this post!
Unread 28-01-2010, 18:13
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Robot Lifting
did anyone come up with an alternative to the CIM motors for some sort of winch climber? Were allready using all 5.
  #81   Spotlight this post!
Unread 28-01-2010, 18:53
EricH EricH is online now
Re: Robot Lifting
FPs with a stock gearbox can work.
  #82   Spotlight this post!
Unread 28-01-2010, 19:02
AKA: Brandon Liatys
Re: Robot Lifting
FPs?
Not familiar. Do you have a pic/spec sheet?
EDIT: Fisher Price?
I found this on it:
http://www.usfirst.org/uploadedFiles...or%20Curve.pdf
Not sure how to read it though though (Im a programmer, leave me alone )
  #83   Spotlight this post!
Unread 28-01-2010, 19:17
Re: Robot Lifting
FPs?
EDIT: Fisher Price?
I found this on it:
Fisher-Price motors they are. Using the kit gearbox and a decent-sized winch can get a pretty fast but powerful lift.
  #84   Spotlight this post!
Unread 28-01-2010, 21:18
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Robot Lifting
Might I suggest this?
  #85   Spotlight this post!
Unread 01-02-2010, 16:04
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Re: Robot Lifting
Originally Posted by TubaMorg View Post
Here is the concept we are implementing to clamp a vertical pole.
Once clamped we will winch the back end of the robot up to the pole.
Initial tests are encouraging, though we will probably have a safety bar that can catch the platform to avoid sliding. Note the same mechanism that winches the robot also engages the clamp, using the robot weight to tighten the grip.
how are you making the clamp engage the tubing? in the picture above, the actual weight of the clamp fingers causes it to initiall close around the cylinder. then as it is hoisted off of the cround the clamp sqeezes tighter - caused by the additional weight of the cyclinder itself. But - gravity is doing the work initially. For the robot, this mechanism would be verticle so you would have to initially get the clamp to squeeze a little around the bar before activating the winch and fully tightening it. I can think of some ways to make this happen - just curious if you have come up with something.
Also, is the plan to attach to one verticle bar or two? I am invisioning a system that would use two but I think aligning them for attachment could be very tricky given the type of clamp. Any thoughts on this?
  #86   Spotlight this post!
Unread 02-02-2010, 16:40
John Moloney John Moloney is offline
FRC #0263 (Aftershock)
Team Role: Webmaster
John Moloney is an unknown quantity at this point
Re: Robot Lifting
I need help with a question the hook we are building, the hook is build to a pipe thats 84in 1/2 O.D. Now my question is,which is legal? Like 84 inches to the ground or 84 inches from the ground to the pipe?
  #87   Spotlight this post!
Unread 02-02-2010, 20:04
bookworm2011's Avatar
bookworm2011 bookworm2011 is offline
FRC #1559
bookworm2011 is an unknown quantity at this point
Re: Robot Lifting
Has anyone considered using a scissor lift mechanism to hang the robot?
"When you reach the end of your rope, tie a knot in the end and hang on."
  #88   Spotlight this post!
Unread 02-02-2010, 20:17
Suigen Yukiouji's Avatar
Suigen Yukiouji Suigen Yukiouji is offline
Master of Gaming
FRC #0999 (Crash)
Suigen Yukiouji is an unknown quantity at this point
Re: Robot Lifting
We had considered it at first, but then a few of our more experienced mentors brought up the size and weight of the lift, and how it would cause problems with the balance of the robot while crossing humps.
  #89   Spotlight this post!
Unread 02-02-2010, 22:01
bobosalad's Avatar
Team Role: Driver
Re: Robot Lifting
yeah we considered it too but i think we are only going to use the scissor lift to lift the wench hook... just ideas. also what do people know about the cim shifter? is it possible to put a shifter in there without the second gear so it would be in neutral?
  #90   Spotlight this post!
Unread 02-02-2010, 22:43
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Robot Lifting
One method we considered was using a lead screw to attach to the pole. We have found, though, that the robot weight is enough to maintain a positive grip. We aren't done enough to drive yet, but we will be using V-type guides to align the gripper. Plus the gripper opens quite wide until engagement.
1070's 2007 Robot Lifting AznPrincess3089 Robot Showcase 8 19-03-2007 19:37
Team 192, Robot Lifting Teaser Joobacca Robot Showcase 7 02-02-2007 17:46
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
