Go to Post I think all drivers will be required to wear tights! - Mike Martus [more]
Unread 30-01-2010, 15:29
Random_Guy Random_Guy is offline
FRC #2729
Random_Guy is an unknown quantity at this point
Changing IP & Default Code
We are attemping to deploy code to the cRIO, but it is defaulting to 10.0.0.2 for the IP. This is not our robot's IP and we cannot figure out how to change it.
Additionally, DefaultCodeProject is not present on our computer. We have looked everywhere and toyed with the installation files, but we cannot find it. We are currently trying to use some sample code that another team uploaded, but it would be greatly appreciated if someone could point us toward a download for the default robot code template.
Unread 30-01-2010, 17:24
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
Re: Changing IP & Default Code
You'll need to set your team number. Are you using NetBeans? If so, this is set under the preferences.
Unread 30-01-2010, 18:27
Lakedaimon's Avatar
Lakedaimon Lakedaimon is offline
FRC #3012 (Spartans)
Lakedaimon is an unknown quantity at this point
In Netbeans, you have to click on "New Project", not "Load Project", in order to see the DefaultCodeProject.
To set the team number, click on Tools->Options->Miscellaneous. There is a box for the team number on the FRC Configuration tab.
Firmware is the most expensive thing in the universe. - Jack G. Ganssle
Unread 01-02-2010, 16:24
FRC #2729
I have been clicking on "New Project." It is not there.
FRC Java
-FRCApplicationProject
-IterativeRobotTemplateProject
-SimpleRobotTemplateProject
Samples --> FRC Java
-TrackerDemoProject
DefaultCodeProject does not exist. In addition to these two locations in the NetBeans "New Project" dialog, we have actually run a search for it through the entire hard drive. We do not have it.
Thank you. We were able to change the IP.
Unread 11-02-2010, 20:31
Torbotics's Avatar
Torbotics Torbotics is offline
FRC #2880
Team Role: Student
Torbotics is an unknown quantity at this point
Exclamation Re: Changing IP & Default Code
We are having the same problem. We open Netbeans, and we followed the directions, but the default program is not on our computer. Where can we go to find that program.
Unread 12-02-2010, 08:41
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
It doesn't sound like you have the latest Java SDK. Newer demo code has been added since the initial release.
Follow the directions on http://first.wpi.edu/FRC/frcjava.html, under
"Getting the Software" to update both the latest NetBeans modules and
the "mandatory LabVIEW update".
If you think you already have the latest modules and they are still not showing up, please check the version.datestamp in the version.properties file in your sunspotfrcsdk directory. The latest version is 201002042135 => 2010/02/04 2135
Changing Default Unit System Richard McClellan SolidWorks 6 28-02-2010 16:09
Camera & Default Code Lablabla Programming 14 28-01-2007 18:25
Problems when combine ADC code && camera code nirhaim1942 Programming 1 24-01-2007 06:58
Victors, Default code, & joystick configuration Vermatitis Control System 4 27-01-2005 16:01
Victors, Default code, & joystick configuration Vermatitis Electrical 4 27-01-2005 16:01
