Go to Post Design is iterative, right? - JesseK [more]
Unread 01-02-2010, 03:34
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: non-pneumatic "kicking" mechanism
Since the only arrangement of elements with any structural integrity is the triangle, and since it is more efficient (less material) to apply and direct force via tension ---
Our kicker is an aluminum triangle "pendulum" made of tee-slot channel with gusset plates at corners and a "toe" on low corner for ball contact. Triangle's top corner clamps to 5/8 axle through ball bearings. At low corner of triangle is attached a 1500lb test 1/8 x 1/4 synthetic cable that runs through forward mounted pulley which turns cable rearward, toward bank of bungee cords, pre-tensioned to ~50LBS. Rear corner of triangle has strong travel stop cord attached to solid frame anchor point. It stops the kick at end of travel, and it sustains the minimum pretension force on bungees.
On its path rearward to the bungee group, the kicker cable passes through a winder plate that is driven by a geared down CIM motor to ~12RPM. Winder rotates 0-180 degrees in just over 2 seconds to shorten tension cable up to 12", depending on desired kick strength (bungee tension rises to ~120Lbs at max.). Kick is triggered by instant disengagement of winder cable from the winder plate using 2" of pneumatic cylinder piston travel to actuate the disengagement. The kick can be triggered at any point in the wind up cycle from 0-180 degrees. The trigger design is a very simple medieval-type concept and there are no other masses accelerated during kick, except the kicker & cable, and that is all I can say about it.
We are waiting to finish the gear box setup for the winder to confirm what level of wind torque it can hold while motor is de-energized. If de-energized motor allows winder to UN-wind, another system will be needed maintain the wind up tension/torque while waiting for the right moment to launch a kick.
Will confirm results of gearbox test when finished.
So far, our kicker has consistently placed shots within a 30" dia. circle at 35+ feet. We still need to "possess" balls well enough to maintain this level of accuracy during match play, and this remains the bigger challenge. We do expect to be able to consistently score two or more goals from far end in autonomous mode.
-RRLedford
Unread 01-02-2010, 06:34
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Here you can see our kicker.
http://www.chiefdelphi.com/forums/sh...highlight=1860
Without pneumatic systems. Only a CIM motor with gear box!!
Unread 01-02-2010, 09:36
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
Our kicker is powered by surgical tubing right now, but for competition we will find something stronger. We pulll it back with a window motor, and we have this sort of locking ratcheting mechanism which we will release with another window motor. Our range is looking to be around 40 feet, but it's variable on how far back we wind up the kicker.
Unread 01-02-2010, 11:15
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Mind posting a video ?
The team from Chile posted a good toughbox kicker video.
http://www.chiefdelphi.com/forums/sh...d.php?p=911126
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 01-02-2010, 14:01
Chris is me's Avatar
AKA: Pinecone
You won't get much stronger than surgical tubing, but if you're looking for more repeatability, bungee cord exchanges a little force for more consistency.
Unread 01-02-2010, 14:17
Originally Posted by Chris is me View Post
... if you're looking for more repeatability, bungee cord exchanges a little force for more consistency.
Hi Chris,
I was wondering if you read this somewhere or if your team discovered it by testing.
Thanks.
Unread 01-02-2010, 14:21
AKA: Pinecone
Hi Chris,
Thanks.
I have read on Delphi that the spring constant of surgical tubing is very temperature-dependent. I've also heard from others' testing (at this time I don't remember who) that their surgical tubing powered prototype had issues with consistency.
Unread 01-02-2010, 16:38
OK thanks. Just wondering, did either of these sources compare the consistency of surgical tubing to bungee cords?
Unread 01-02-2010, 17:09
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
I'm not so sure that the use of bungee cords sacrifice force when compared to surgical tubing.
You can easily make up for it by applying more/different bungee cords to achieve the force you are looking for. If consistency and durability are better with the bungees, its a no brainer, right?
Unread 01-02-2010, 17:29
viper110110 viper110110 is offline
FRC #1325
viper110110 has a spectacular aura aboutviper110110 has a spectacular aura aboutviper110110 has a spectacular aura about
Our kicker is going to be a large spinning blade/paddle thing. We will be able to adjust the speed/turn it off at will, allowing us to control the ball how we want to. Our tests give us about 10-15 feet, but we are changing the kicker mechanism now to have a larger paddle and possibly 2 motors.
Unread 01-02-2010, 18:19
If.
The veracity of the premise has not yet been established.
Unread 01-02-2010, 18:22
Do the spinning paddles/blades extend outside a vertical projection of the frame perimeter?
Unread 01-02-2010, 18:25
Just curious: why don't you just double-up (or triple-up) the tubing? That will make it twice (or three times) "stronger".
Unread 01-02-2010, 18:27
Team Role: Driver
Yeah exactly. I guess one of our team members read somewhere on CD about harpoon gun tubing so now one of our mentors plans to get us a few different diameters of the stuff so we can figure out what works best. There are a lot of stretchy materials to use, and surgical tubing is probably not the ideal material.
Unread 01-02-2010, 20:14
spacegy4's Avatar
spacegy4 spacegy4 is offline
Is a CAD
AKA: Andrew Sternglass
FRC #0639 (Code Red Robotics)
spacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to all
Send a message via AIM to spacegy4 Send a message via MSN to spacegy4 Send a message via Yahoo to spacegy4
The spinning wheel is in! We call it the spinning tounges of death!
http://cms.team639.org/node/113
"When you pull the project out of the fire and make the robot dance, thats real education."
Woodie Flowers: 2010 Kickoff
Extra "non-vex" sensors MRClark VEX 2 22-01-2008 16:46
Controlling a "fork lift" type mechanism. Brad Voracek Programming 4 18-01-2007 22:53
FIRST "Final 4": Ready for live TV (non-NASA TV)? David Brinza General Forum 15 10-05-2006 00:02
Non-Engineering Mentor "Meet and Greet" in Atlanta! KathieK Championship Event 0 27-03-2005 09:43
"Ball Return" mechanism... what is it? Randy_Ai Rules/Strategy 1 09-01-2002 16:12
