Re: sending info to a console
Where are they called from? How quickly are they called? Does rebooting the robot affect anything, or is restarting the driver station application the only thing that makes it work again?
I just got in here a little while ago... It turns out that the problem was not related to the calls to DriverStationLCD, removing those lines only made the error occur much later. All is well now. Thanks.
Thanks -Joe |
I did not see the exceptions because I was using a development machine separate from the DS. Fixing that by properly sizing the array was the solution (i'm ashamed that I missed this)I do not know why commenting the two lines with DriverStationLCD seemed to delay the problem. It may have been a coincidence... I apologize for the confusion. DriverStationLCD appears to work as intended and was not the cause of my trouble. Thank you for your responses. Regards, Bill |
| Sending data from RC to OI | Nathan | Programming | 7 | 03-02-2008 22:32 |
| sending extra information to the OI | iwdu15 | Programming | 2 | 06-02-2007 20:05 |
| Sending variables to Auto Mode | Adrien | Programming | 4 | 19-02-2006 21:51 |
| Sending data back to the OI | DanDon | Programming | 13 | 26-01-2006 15:17 |
| Sending Data | Raven_Writer | Programming | 8 | 11-09-2003 16:28 |
