Go to Post I think I just found a way to replace our entire robot drive team! (no big deal, they are graduating anyway!) :D - dlavery [more]
Unread 31-01-2010, 12:33
nabioullinr nabioullinr is offline
FRC #1073
nabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura about
Re: Help with 2010 Accelerometer & I2C
For some reason I keep receiving 0.0 from GetAcceleration(); am I instantiating the accelerometer correctly?:
ADXL345_I2C(4, ADXL345::kRange_2G)
(assuming the digital sidecar is connected to slot 4)
Unread 31-01-2010, 13:54
FRC #1073
We attached an oscilloscope to the bus and noticed that the data returned from the slave accelerometer is 0 for all three transactions (x, y, z); could it be attributed to some sort of a power saving feature which is not disabled?
Unread 31-01-2010, 16:23
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I'm guessing you didn't fix WPILib... http://www.chiefdelphi.com/forums/sh...5&postcount=12
If you fix the I2C library it should start working for you.
Unread 01-02-2010, 15:52
FRC #1073
How would I patch wpilib? I could not find anything useful (besides the description of the bug).
Unread 01-02-2010, 16:07
Download the source code, change the logical OR to a bitwise OR, build the library, run the Scripts/updateBuiltInLibrary.cmd file to install the compiled library, rebuild your project.
-Joe
Unread 01-02-2010, 16:41
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Will this patch be in a team update soon? It's not good that teams already have gone this long with broken support for something in the KoP...
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 01-02-2010, 16:57
I'm not sure... I have no control over release schedules.
I know... that's why I've tried to provide timely workarounds, fixes, problem notifications, feature implementation examples, and support the best I can so that teams will not be held up by the release schedules. It's not ideal to need to patch these things manually, but it's also not good to force every team to install and keep track of 10+ updates in various languages that would all be released independently and out of phase with each other. Many teams can't keep up with the one update released at kickoff.
-Joe
Unread 01-02-2010, 18:21
tdidi tdidi is offline
FRC #2619
tdidi is an unknown quantity at this point
-Joe
I don't get it. I follow those instructions exactly, and it removes the WPILib from Windriver completely when I run the updateBuiltInLibrary.cmd.
I get the "no such file or directory" error.
Unread 01-02-2010, 18:33
That probably means you didn't build the library successfully. Make sure you build the debug version, since that's what the script copies.
What file or directory exactly does it fail on?
-Joe
Unread 01-02-2010, 18:48
FRC #2619
ok, I made a new project in Windriver. I copied the entire WPILib and its files (most recent release) into that project, and made the change to the logical OR.
The build target is specified as "Windows-gnu-native-3.x-4.x-debug" (I'm assuming thats what you mean by building the debug version.)
The error is that it can't find "WPILib.h" after I run the updateBuiltInLibrary.cmd
Unread 01-02-2010, 18:52
ok, I made a new project in Windriver. I copied the entire WPILib and its files (most recent release) into that project...
The script is expecting the library source to be in "c:\WindRiver\workspace\WPILib" and if it's not there you will get this behavior.
Unread 01-02-2010, 18:59
FRC #2619
Thank you sir. You have been most helpful!
Unread 02-02-2010, 00:59
AKA: Harry Bock
FRC #1350 (Rambots)
-Joe
That's quite understandable. Maybe in future seasons it'd be a good idea to do something along the lines of providing weekly updates that merge in the most critical patches for each language; updates that are helpful but not necessary would be included at longer intervals, perhaps only once per season.
The updates could be optional (e.g., not an 'official mandatory' team update) until the season draws to a close to prevent teams freaking out over things that aren't affecting them until ship draws close.
In any case, thanks a lot for your replies and the hard work you've been doing to make the lives of FIRST teams easier
Unread 03-02-2010, 19:34
FRC #2619
Should the cRIO need to be re-imaged for the patched WPILib to take effect?
I find that I am still unable to write to the device.
Extra details:
I know I'm not writing to the device because after I write to PowerControl and DataFormat regAddress's, I read them, and get back nothing (0). I know I'm reading correctly because I can get the DeviceID just fine. I have patched the WPILib as previous posts have instructed, but I think there might be a missing last step or something obvious that I'm missing.
Unread 04-02-2010, 02:22
Extra details:
The cRIO does not need to be reimaged for the WPILib patch to take effect. WPILib is a static lib that is linked with your program and deployed with your application. If I were you I would double check that you are successfully building the library, running the script to install it, and relinking your application. Do something that would prove all these steps are working such as putting a printf inside one of the I2C methods you are changing. If it prints, you know you have linked against the new version of the library.
-Joe
2010 Accelerometer Documentation? JDM Sensors 13 18-01-2010 12:42
Accelerometer Help? elbuo Programming 16 19-01-2009 13:01
accelerometer help!! wildcats Electrical 2 18-01-2009 15:51
Accelerometer Help! Questions4mQ202 Electrical 4 15-01-2009 19:44
Accelerometer help Red Mage Programming 3 30-01-2008 18:49
