Go to Post If I had a dollar for every time I thought we'd get a legitimate hint....Well, I might have a few dollars... - Andrew Blair [more]
Unread 01-02-2010, 18:33
Re: Bungy and Surgical tubing
Originally Posted by boomergeek View Post
I doubt Bimba will get an actuator engineer to stick his/her neck out and put out a blanket statement that say 20 ips can be exceeded
I doubt the surgical tubing manufacturer will get an engineer to stick his/her neck out and put out a blanket statement that say the tubing is safe to use to arm a soccer-ball kicker.
The line has to be drawn somewhere.
Surgical Tubing spring rate? Tom Line Technical Discussion 9 30-01-2011 14:33
Surgical Tubing? rogue5n1per Kit & Additional Hardware 1 19-01-2010 22:05
How do you connect surgical tubing? Marlfox Technical Discussion 7 17-01-2009 15:19
[OCCRA]: Surgical Tubing iwanttodunk OCCRA Q&A 1 07-10-2008 06:28
Surgical Tubing punky2k1 Off-Season Events 1 24-10-2001 20:58
