Go to Post The term defensive robot and mechanum wheels do not belong in the same sentence together. - Koko Ed [more]
Unread 01-02-2010, 18:51
NerdGuy's Avatar
NerdGuy NerdGuy is offline
FRC #2974
NerdGuy is an unknown quantity at this point
rearrange crio modules?
Hey so we need to rearrange our crio modules.
dont ask why we just need to.
However when we rearanged the modules and reformated the crio the code does not work. The driver station displays no I/O found. in the diagnostics tab.
Does anyone know how to make this work?
Also we are using Java so that might have something to do with it.
"Life would be so much easier if we only had the source code."
Unread 01-02-2010, 19:05
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: rearrange crio modules?
That's a shame... cause it's not possible. The FPGA is compiled to expect certain modules in specific slots.
Not sure what you mean by "displays no I/O found". Displays it where? Is that exactly what it says? This is likely a message about the Cypress I/O board and has nothing to do with moving the modules.
Nope... no one does... since it's not possible.
Unread 01-02-2010, 19:40
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
super easy - put the modules in the slots indicated by the manual.
Ed Barker
Unread 01-02-2010, 20:03
You can swap some of the modules:
  • slot 1 can be swapped with slot 2
  • slot 4 can be swapped with slot 6
  • slot 7 can be swapped with slot 8
But that's probably not much help is it?
Unread 01-02-2010, 23:45
NerdGuy's Avatar
FRC #2974
*sigh
Just as i had feared, oh well we will just put them back like they were.
Thanks anyway.
Unread 02-02-2010, 00:25
That is inaccurate... While you "can" swap 1 and 2 and you "can" swap 4 and 6, you are required to have a 9201 in slot 1 and a 9403 in slot 4.
-Joe
Unread 02-02-2010, 08:56
I believe "swap" is accurate, while "move" would not be, except for slots 7 & 8.
But it was tongue in cheek.
Unread 02-02-2010, 15:09
Fair enough. This whole topic is a bit comical.
Unread 12-02-2010, 17:52
SovietChaoz's Avatar
SovietChaoz SovietChaoz is offline
FRC #1647 (Iron Devils)
Team Role: Electrical
SovietChaoz is an unknown quantity at this point
so can you move the ni 9472 module to a slot other than 8 or 7?
--GET$--
Unread 12-02-2010, 18:10
No.
multiple cRIO relay (solenoid) modules? Alan Anderson FRC Control System 15 06-02-2010 17:41
cRIO unused Modules marisaDKNY Electrical 2 07-02-2009 16:58
pic: cRIO Model with I/O Modules in Inventor Ed Sparks Extra Discussion 5 22-12-2008 22:17
Vishay IR Reciever modules EIROBOTICS86 Electrical 4 04-02-2004 00:18
RF Modules archiver 1999 1 23-06-2002 22:06
