Go to Post This is high school robotics for fun and education. Let's try and keep it that way. - Rod [more]
Unread 20-01-2010, 16:47
a kenny03 a kenny03 is offline
Robotics for life(stupid classmate)
AKA: PICKELL!!!
FRC #0219 (Team Impact)
a kenny03 is an unknown quantity at this point
Send a message via AIM to a kenny03
sending info to a console
so our team is using java this year, and we have been experiencing difficulty with sending output data to the classmate console. anyone have any way to help me out?
Unread 20-01-2010, 19:46
James Dempsey James Dempsey is offline
Overtired Programmer
AKA: Rooster Cogburn
FRC #1559 (Devil Tech)
James Dempsey is an unknown quantity at this point
Re: sending info to a console
If you are trying to send an output to the console on a development computer, you must use the System.out.print or println methods to send data to the console wheter it be strings, integers, characters etc.
If you want to send information to the dashboard, look through the sample code provided with the FRC plugin in NetBeans.
Hope this helps
James D
Edit:
After re-reading your post it sounds like you are trying to send data to the User Messages section of the Dashboard. To access the lower part of the Dashboard you must use the class Dashboard. Here is an example of how to have a class object for the lower half of the Dashboard:
Dashboard lowDashData = DriverStation.getInstance().getDashboardPackerLow( );
You then have to add clusters in order to be able to send your data.
Again sorry if you already knew this but I hope this helped you
Last edited by James Dempsey : 20-01-2010 at 20:15. Reason: Additional Information
Unread 21-01-2010, 09:05
AKA: PICKELL!!!
yeah. i want something like the console from last year. we use windriver, and our team was able to get output data from the robot. thats what we are trying to replicate or get as close as possible
Unread 21-01-2010, 16:44
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I believe that's inaccurate. If you want to send strings to the User Messages, on the Driver Station, you need to use the DriverStationLCD class. If you want to send data to a Dashboard (where you would have to add a text box or other controls), then you use the Dashboard class.
Unread 21-01-2010, 21:46
Yes my mistake. I was extremely tired when I responded to this post. The DashboardLCD class should be the class you would use. Here is the link for methods and such:
http://www.wbrobotics.com/javadoc/ed...tationLCD.html
Again sorry for the confusion there on my misinformation, my bad.
Unread 21-01-2010, 22:36
AKA: PICKELL!!!
i have the import for the driverstationlcd class, but i have no clue what to do with it... i think one of my fellow team members might have been able to solve this problem, but i don't know if it works. (that's tomorrow's job)
another note...
does anyone know what 'private access' means, and how to get past it?
Unread 21-01-2010, 22:42
another note...
All you need to do is call println() for each line you want to send and then call updateLCD() once after println'ing all the lines that you want to send. You don't need any private members.
Unread 22-01-2010, 10:16
AKA: PICKELL!!!
well, i figured that *face palm* but i am still getting an error. i am using the dsLCD class, but i am still getting a private access error
this is my code...
DriverStationLCD robot = new DriverStationLCD();
robot.println(DriverStationLCD.Line.kUser2,1,"this prints on the first line");
robot.updateLCD();
Unread 22-01-2010, 11:30
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Hi A Kenney03,
Call "DriverStationLCD getInstance()" instead of "new DriverStationLCD()".
Since there can only be one DriverStationLCD, the private access prevents you from trying to create two objects to refer to the same item on the driver station.
BTW, errors like this are easier to comment on if you can post the error message. I wasn't sure if you were talking about a compile error, network error, code error, or what :-)
Unread 22-01-2010, 16:34
AKA: PICKELL!!!
ok. thank you. that helps. but new we are having trouble with the user messages system. is there a maximum limit on strings and lines? and how do we use the first line?
Unread 22-01-2010, 23:19
There are 6 lines... 21 characters per line. This is based on compatibility with last year's DS.
To use the first line, use the enum value to specify the first line.
Unread 31-01-2010, 22:42
full_auto full_auto is offline
AKA: Bill
FRC #1168
full_auto is an unknown quantity at this point
Send a message via AIM to full_auto
Hey guys, first post here.
We are also having trouble with using DriverStationLCD. The code that I am attempting to use is as follows:
textOut.println(DriverStationLCD.Line.kUser3, 2, message);
textOut.updateLCD();
where 'textOut' is an instance of DriverStationLCD retrieved with DriverStationLCD.getInstance() and 'message' is a String that is never more than 15 characters.
This code is executed periodically. The problem is that after it executes a few times the DS stops responding and must be restarted to regain functionality. This does not happen if I remove those two lines, so I'm fairly sure that they are the cause.
Has anyone gotten this to work? Any help is greatly appreciated.
Unread 01-02-2010, 17:53
AKA: Bill
FRC #1168
Nobody knows anything that could help?
Unread 01-02-2010, 18:31
Where are they called from? How quickly are they called? Does rebooting the robot affect anything, or is restarting the driver station application the only thing that makes it work again?
Unread 01-02-2010, 19:18
AKA: Bill
FRC #1168
I just got in here a little while ago... It turns out that the problem was not related to the calls to DriverStationLCD, removing those lines only made the error occur much later. All is well now. Thanks.
Sending data from RC to OI Nathan Programming 7 03-02-2008 22:32
sending extra information to the OI iwdu15 Programming 2 06-02-2007 20:05
Sending variables to Auto Mode Adrien Programming 4 19-02-2006 21:51
Sending data back to the OI DanDon Programming 13 26-01-2006 15:17
Sending Data Raven_Writer Programming 8 11-09-2003 16:28
